Aim PDM 10" Support de tableau de bord
Choose Accessories
Free Shipping Above £100
Mount Your System
The Aim PDM 10" Dash Bracket is a precision bracket designed to secure your 10” Dash Display in perfect alignment with your PDM08 or PDM32 unit, mounting neatly on the steering column.
Why Choose the Aim PDM 10" Dash Bracket
Crafted from 2mm thick stainless steel with a raw finish, the bracket includes interchangeable components to facilitate the mounting of displays, buttons, dash, lap timers and shift lights. The Aim PDM 10” Dash Bracket is built for flexible installation: you can use it with a central hub, weld-on tabs, or bolt-on tabs, and it even works without steering wheel mounts if preferred. It gives you the exact positioning and durability you need for your setup.
10" Support de tableau de bord PDM
