Mount Your System
The Aim SmartyCam Bullet Camera U Bolt Mount is designed to mount a SmartyCam bullet camera to a vehicle's roll bar, railing or tube that has a diameter between 0.5 to 1.2 inches. It is suitable for SmartyCam 2.1, 2.2, 3 and 4 Dual and GP models.
Why Choose the Aim Bullet Camera U Bolt Mount
The Aim SmartyCam Bullet Camera U Bolt Mount is a versatile way to secure a bullet camera to a range of vehicle setups. The mount is easy to set up; simply attach the U bolt to the vehicle, and secure using the lock nuts for a secure fit. The ball and socket system allows you to easily adjust your camera angle, while the rubber insert minimises vibration, ensuring you get the best recordings of your laps.
  • For use with SmartyCam GP & Dual 2.1 & 2.2, 3 & 4 bullet cameras
  • 60mm arm
  • Ball & socket adjustment system
  • Suitable for 0.5 to 1.2" bar
  • Designed to withstand the rigours of motorsport
SKU: SM-UB-GP
Part Number: X90KSBLTP
