1 de 3
AiM SmartyCam External Power Harness
SKU: SM-EXP
Prix ​​habituel
£40.00
Prix ​​habituel
Prix ​​de vente
£40.00
The AiM SmartyCam GP HD 2.1 & 2.2 external power harness can be used to be connected to an external battery.
Suitable for all SmartyCam  External power cable 12V
712 - 7 pins connector Two free wires
The AiM SmartyCam external power harness can be used to be connected to an external battery.
The power lead fits the SmartyCam and the two un-terminated free wires will connect to a 12V battery.
The cable length is 2m.
  • SmartyCam External Power Harness
  • Allows external battery connection 12V
  • 712 - 7 pin male connection
  • Cable length: 2m
  • 1 x SmartyCam External Power Harness
The AiM SmartyCam external power harness can be used to be connected to an external battery. The power lead fits the SmartyCam and the two un-terminated free wires will connect to a 12V battery. The cable length is 2m.
  • Cable length: 2m
