Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    SmartyCam GP Suction Cup Mount For Recording Box - AimShop.com
    SM-WM-GP-R
    En stock, prêt à être expédié
    £80.00
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £80.00
    Aim SmartyCam GP HD Suction Cup Mount For Recording Box
    The SmartyCam GP HD can be installed using the GP HD suction cup mount. It is suitable for SmartyCam GP HD 2.1, 2.2 & 3 SmartyCams.
    Secure mounting for SmartyCam
    Ball & socket system
    Complete with fitting kit
    GP HD 2.1, 2.2 & 3 Compatible
    The Aim SmartyCam GP HD suction cup mount for the recording box is for mounting the SmartyCam's recording box to a windscreen or flat surface.
    The suction cup mount has a unique ball and socket system which offers optimum positioning and has been designed to cope with the rigours of motorsport.
    The mount will keep the recording box safe and secure and can be placed in a position clear from the driver so it doesn't get in the way.
    Suction Cup Mount
    Securely attaches to any windscreen or flat surface.
    Includes all fixtures and fittings.
    AiM SmartyCam GP HD Suction Cup Mount For Recording Box 2.1 & 2.2 & 3
    • For use with SmartyCam 2.1 & 2.2 & 3 GP HD
    • Arm height 90mm ( 3.54 inches)
    Aim SmartyCam GP HD Suction Cup Mount For Recording Box 2.1, 2.2 & 3
    • Suction cup
    • 90mm arm
    • Clamp base with ball
    • Mounting bracket
    • Locknuts
    • Washers and screws
    Technical sheet Race Studio 3
