1 de 2
AiM SmartyCam GP HD Bullet Cam Roll Cage Mount 2.1 & 2.2 Motorcycle
SKU: SM-VB-GP-MC
Prix ​​habituel
£80.00
Prix ​​habituel
Prix ​​de vente
£80.00
Fits the SmartyCam GP HD camera Ball & socket adjustment system
Clamp to a wide range of diameter tubing For SmartyCam GP HD 2.1 & 2.2
Roll Cage Mount
  • For use with SmartyCam GP HD 2.1 & 2.2
  • Arm height 60mm ( 2.36 inches)
  • Handlebar bracket
  • 60mm arm
  • Ball head
  • Bullet cam bracket
Technical sheet Race Studio 3
The AiM SmartyCam GP HD 2.1 & 2.2 roll cage mount has been designed to securely mount the SmartyCam GP HD 2.1 & 2.2 bullet camera. The roll cage bracket (v-bracket) adjusts using a ball and socket system for optimum positioning and simply clamps to roll bars of a wide range of diameters. The 44mm & 55mm tube clamps enable you to attach the mount to different sized roll bars.
Roll Cage Mount
  • Handlebar bracket
  • 60mm arm
  • Ball head
