AiM SmartyCam GP HS 2.2 Replacement Bullet Camera Kart
SKU: SM-GP-C-67-R2 - XB1SGPH22B67
- Prix habituel
- £500.00
- Prix habituel
- Prix de vente
- £500.00
- Prix unitaire
- par
AiM SmartyCam GP HD 2.2 Replacement Bullet Camera
The AiM SmartyCam 2.2 GP HD replacement Bullet Camera, is a lightweight, robust replacement or spare part for your camera kit.
High quality camera | Replacement for SmartyCam 2.2 |
Compact & robust | Lens options 67°, 87°, 120° |
The AiM replacement bullet camera has been designed for motorsport and is incredibly light and robust.
The bullet camera is black anodised, billet machined small and compact enough to fit into the tightest of locations.
Ideal to have one spare at the track incase your camera gets damaged.
Provides high quality footage.
Lens Options
The replacement bullet camera is available in three lens versions.
The 67° lens is preferred to see the track in front of you
The 87° lens is available to have a more ample view of the track.
The 120° lens gives an even wider view of the track and surroundings.
Please Note: This replacement Bullet Camera is for the SmartyCam 2.2 GP HD. If you need a replacement for the SmartyCam 2.1 GP HD see the Accessories Tab.
We also have have Bullet replacement front glass kits available in three different lens applications.
These are some of the items that can be added to your kart for incrementing performance and data.
- Anodised black
- Billet machined
- Available in 67°, 87°, 120° lens
- 1 x Replacement Bullet Camera
- Lens option available 67°, 87°, 120°
The AiM SmartyCam 2.2 GP HD replacement Bullet Camera, is a lightweight, robust replacement or spare part for your camera kit.Key Features :
The AiM replacement bullet camera has been designed for motorsport and is incredibly light and robust.The bullet camera is black anodised, billet machined small and compact enough to fit into the tightest of locations.
Lens Options
The replacement bullet camera is available in three lens versions.The 67° lens is preferred to see the track in front of you
These are some of the items that can be added to your kart for incrementing performance and data. ![]() |
- Anodised black
- Billet machined
