Aim Support à ventouse SmartyCam
Mount Your System
The Aim SmartyCam Suction Cup Mount is the simple and secure solution to mounting your SmartyCam onto any flat surface in your vehicle. It is suitable for the SmartyCam HD 2.1, SmartyCam 3 Sport and SmartyCam 3 Corsa.
Why Choose the Aim SmartyCam Suction Cup Mount
The Suction Cup Mount is the most secure and easiest way to view your SmartyCam when you’re on the track in your vehicle. The mount is simple to set up, just latch the suction cup onto any flat surface, and the camera will remain sturdy and secure, without having to worrying about the camera falling. The ball and socket allows you to conveniently position the camera to suit your lap line, ensuring maximum visibility of your laps for post-session reviews.
