1 de 4
Aim Solo 2 DL GPS + ECU Motocross Track Day Lap Timer
SKU: SOLO2-K2
Prix ​​habituel
£630.00
Prix ​​habituel
Prix ​​de vente
£630.00
A highly-precise GPS lap timer with ECU connectivity for offroad motocross bikes. It provides accurate speed, lap timing and engine metrics, with Wi-Fi data transfer and RS3 for performance analysis
The Most Precise & Easy Way To Get Lap Times
Upgrade your offroad motocross setup with one of the best motorsport lap timers in the industry — the Solo 2 DL GPS Lap Timer. Equipped with a 25 Hz GPS, ECU connection, built-in gyro, user-friendly interface and compatibility with session performance analysis software, the Solo 2 DL provides precise lap times and detailed telemetry for amateur and professional riders to optimise their performance and achieve their track day goals.
Solo 2 DL Key Features
Direct ECU Data Logging
Predictive Lap Timing
Extensive Track Database
8 Different Colour Backlights
10 Configurable RGB LEDs
Choice Of Connection
Multiple Race Modes: Speed, Times & Performance
Integrated GPS & GLONASS Receiver
8 Configurable Display Pages
Automatic Track Recognition
Internal 4GB Memory
Wi-Fi Connection
Solo 2 DL Offroad Motocross Track Day Lap Timer
Solo 2 DL With ECU Connection
Aim Solo 2 DL is the most precise GPS lap timer with the ability to show lap times live as you drive due to data from two satellite constellations from anywhere globally by using GPS and Glonass, which ultimately gives a significant improvement in data speed and positioning precision.
Start up time is reduced to seconds and lap times are accurate to a tolerance of two-hundredths of a second.
The Solo 2 DL can be connected to the motocross bike's ECU to obtain various data from the sensors you have fitted to your bike. Solo 2 DL manages all the hardware ECU connections and all the communication lines: depending on whether you want to connect to the ECU using the OBDII port or directly to the ECU through the CAN/RS232 channel. If the ECU protocol is not supported, the connection to the Solo 2 DL to a coil RPM will provide a digital input delivered from square wave signals or pulse signals.
The sampled data you record depends on the actual ECU, typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is constantly updated.
Add a SmartyCam HD/GP HD camera to create an even mightier system to help provide you with incredible videos that include all the technical information to help improve your performance.
Solo 2 DL gives instant speed; timing splits live data and predictive lap times.The Solo 2 DL has a sharp, high contrast display which helps drivers easily identify the data displayed on the screen. The Solo 2 DL also features a selection of 7 different backlight colours, which you can select to suit your requirements.
The GPS technology provides better reliability from the predictive lap timing function, so you can see in real-time how your current lap compares to your best lap. The LEDs are also configurable to give a visual indication of whether you are quicker or slower. You can also build the layout of the display to show the data you want to see.
Data Recall On Screen
Solo 2 DL can be used for circuit racing and point to point or regularity events and performance tests such as 0-60mph. And just like the circuit racing mode, all the data is recorded and can be reviewed immediately after each race or test session.
Solo 2 DL allows you to create a new temporary or permanent track layout. Whether it's a point to point run for rallying or a closed-loop track.
Wi Fi Communication With The PC
The Solo 2 DL has integrated Wi Fi. If you want to review your data in more depth, transfer your data securely and quickly onto a laptop or computer up to 50m away without the need for connectors and cables. You can then import the data into the Race Studio 3 software.
Compatible Expansions
Add SmartyCams and a Lambda Control Unit to increase your data performance.
With Race Studio 3, you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You can also manage the map of all your racing tracks and compare two laps by watching the video recorded by SmartyCam HD cameras.
With Race Studio 3, you can also analyse all data recorded by Solo 2 DL and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve race times.
Aim Solo 2 DL Lap Timer GPS + ECU Offroad Racing Dash Logger
  • Display: Graphical
  • Backlight: 8 configurable RGB colours
  • Wi-Fi connection: Yes
  • GPS: 25 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Dimensions: 98.0 x 73.7 x 30.2mm
  • Weight: 240g, battery included
  • Waterproof: IP67
Solo 2 DL Pinout
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • Aim Sticker
  • Choice of power leads available as selected at checkout. Only One Supplied
  • CAN/K-Line external power cable with OBDII connector
  • CAN/RS232 external power cable
  • RPM external power cable (if your vehicle has no ECU)
Internal 4GB Memory
Wi-Fi Connection
  • GPS: 25 Hz
  • Memory: 4 GB
  • Waterproof: IP67
Solo 2 DL Pinout
What's In The Box
  • Solo 2 DL
  • User manual
  • Aim Sticker
