{"product_id":"aim-solo-2-dl-motocross-track-day-lap-timer-kit","title":"\u003ctc\u003eAim\u003c\/tc\u003e Kit chronomètre Solo 2 DL Motocross Track Day","description":"\u003cp style=\"display: none;\"\u003eChronomètre GPS haute précision avec connectivité ECU pour motos de motocross tout-terrain. Il fournit des mesures précises de vitesse, de temps au tour et de données moteur, avec transfert de données Wi-Fi et RS3 pour l'analyse des performances.\u003c\/p\u003e  \u003cstyle\u003e\n    .LandingPage-CatTitle {\n        font-size: 24px;\n        text-align: center;\n      font-weight:600;\n    }\n    .LandingPage-CatSubTitle {\n        font-size: 22px;\n        text-align: center;\n      margin:0;\n      font-weight:600;\n    }\n    .TextBoxes {\n        font-size: 20px;\n        line-height: 32px;\n        text-align: center;\n    }\n  .features_container {\n  max-width: 1200px;\n      margin: 0 auto;\n padding-top: 20px !important;\n      padding-bottom: 20px !important;\n}\n\n.features_title {\n  font-size: 32px;\n  font-weight: 700;\n  text-align: center;\n  margin-bottom: 40px;\n  color: #333;\n  text-transform: uppercase;\n  letter-spacing: 1px;\n}\n\n.features_grid {\n  display: grid;\n  grid-template-columns: repeat(2, 1fr);\n  gap: 20px;\n  background-color: #f9f9f9;\n  padding: 30px;\n  border-radius: 8px;\n  box-shadow: 0 2px 10px rgba(0, 0, 0, 0.05);\n}\n\n.features_item {\n  font-size: 16px;\n  color: #555;\n  text-align: center;\n  padding: 15px;\n  background-color: #fff;\n  border: 1px solid #eee;\n  border-radius: 4px;\n  transition: transform 0.2s ease, box-shadow 0.2s ease;\n}\n    @media (max-width: 768px) {\n        .LandingPage-CatTitle {\n            font-size: 22px;\n        }\n        .LandingPage-CatSubTitle {\n            font-size: 20px;\n        }\n        .TextBoxes {\n            font-size: 18px;\n            line-height: 32px;\n        }\n    }\n\n\/* Mobile adjustments *\/\n@media (max-width: 600px) {\n  .features_grid {\n    grid-template-columns: 1fr; \/* Single column on mobile *\/\n    padding: 20px;\n  }\n\n  .features_title {\n    font-size: 24px;\n    margin-bottom: 30px;\n  }\n\n  .features_item {\n    font-size: 14px;\n    padding: 12px;\n  }\n}\n    \u003c\/style\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eLe plus précis \u0026amp; Méthode simple pour obtenir des temps au tour\u003c\/h2\u003e  \u003cp class=\"TextBoxes\"\u003eAméliorez votre équipement de motocross tout-terrain avec l'un des meilleurs chronomètres de course du marché : le Solo 2 DL GPS. Doté d'un GPS 25 Hz, d'une connexion ECU, d'un gyroscope intégré, d'une interface intuitive et compatible avec les logiciels d'analyse de performance, le Solo 2 DL fournit des temps au tour précis et des données télémétriques détaillées permettant aux pilotes amateurs et professionnels d'optimiser leurs performances et d'atteindre leurs objectifs sur circuit.\u003c\/p\u003e  \u003cdiv class=\"features_container\"\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003ePrincipales caractéristiques de Solo 2 DL\u003c\/h2\u003e  \u003cdiv class=\"features_grid\"\u003e  \u003cdiv class=\"features_item\"\u003eEnregistrement direct des données de l'ECU\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eChronométrage prédictif au tour\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eBase de données de pistes étendue\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003e8 couleurs de rétroéclairage différentes\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003e10 LED RVB configurables\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eChoix de connexion\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003ePlusieurs modes de course : vitesse, temps \u0026amp; Performance\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eGPS intégré \u0026amp; Récepteur GLONASS\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003e8 pages d'affichage configurables\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eReconnaissance automatique des pistes\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eMémoire interne de 4 Go\u003c\/div\u003e  \u003cdiv class=\"features_item\"\u003eConnexion Wi-Fi\u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003chr\u003e  \u003cdiv style=\"text-align: center;\"\u003e\u003cimg alt=\"Solo 2 DL Offroad Motocross Track Day Lap Timer\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Solo-2-DL-Display-Colours_240x240.gif?v=1613590480\"\u003e\u003c\/div\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eSolo 2 DL avec connexion ECU\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003e\u003ctc\u003eAim\u003c\/tc\u003e Le Solo 2 DL est le chronomètre GPS le plus précis, capable d'afficher les temps au tour en direct pendant que vous conduisez grâce aux données de deux constellations de satellites, depuis n'importe où dans le monde, en utilisant GPS et Glonass, ce qui permet une amélioration significative de la vitesse des données et de la précision du positionnement.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eLe temps de démarrage est réduit à quelques secondes et les temps au tour sont précis à deux centièmes de seconde près.\u003c\/p\u003e  \u003chr\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eConnexion facile\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eLe Solo 2 DL se connecte au calculateur moteur (ECU) de votre moto cross pour récupérer diverses données provenant des capteurs installés. Il gère l'ensemble des connexions matérielles et des lignes de communication avec le calculateur : soit via le port OBDII, soit directement via le canal CAN\/RS232. Si le protocole du calculateur n'est pas pris en charge, la connexion du Solo 2 DL à un capteur de régime de bobine (RPM) fournit un signal numérique sous forme d'onde carrée ou d'impulsion.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eLes données enregistrées dépendent du calculateur moteur (ECU) utilisé et comprennent généralement le régime moteur, la charge moteur, la position du papillon des gaz (TPS), les températures d'huile, d'air et d'eau, la pression d'huile, la tension de la batterie, la vitesse, le rapport engagé et le rapport air\/carburant (valeur lambda). La liste des calculateurs est mise à jour en continu.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eAjoutez une caméra SmartyCam HD\/GP HD pour créer un système encore plus performant qui vous fournira des vidéos incroyables incluant toutes les informations techniques nécessaires à l'amélioration de vos performances.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eSolo 2 DL offre une vitesse instantanée ; le chronométrage compare les données en direct et les temps au tour prédictifs. times.The Le Solo 2 DL est doté d'un écran net et à contraste élevé qui permet aux conducteurs de lire facilement les données affichées. Il propose également un choix de 7 couleurs de rétroéclairage différentes, que vous pouvez sélectionner selon vos préférences.\u003c\/p\u003e  \u003cdiv style=\"text-align: center;\"\u003e  \u003c!-- SÉPARATEUR --\u003e\u003chr class=\"ProductDescription\"\u003e  \u003c\/div\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eChronomètre prédictif\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eLa technologie GPS améliore la fiabilité du chronométrage prédictif, vous permettant de comparer en temps réel votre temps au tour actuel à votre meilleur temps. Les LED sont configurables et indiquent visuellement si vous êtes plus rapide ou plus lent. Vous pouvez également personnaliser l'affichage pour visualiser les données de votre choix.\u003c\/p\u003e  \u003cdiv style=\"text-align: center;\"\u003e\u003chr class=\"ProductDescription\"\u003e\u003c\/div\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eRappel de données à l'écran\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eLa Solo 2 DL peut être utilisée pour les courses sur circuit, les épreuves de régularité et les tests de performance comme le 0-60 mph (0 à 96 km\/h). Tout comme en mode circuit, toutes les données sont enregistrées et peuvent être consultées immédiatement après chaque course ou séance d'essais.\u003c\/p\u003e  \u003cdiv style=\"text-align: center;\"\u003e\u003chr class=\"ProductDescription\"\u003e\u003c\/div\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eSolo 2 DL Nouvelle création de pistes et notre base de données de pistes\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eSolo 2 DL vous permet de créer un nouveau tracé, temporaire ou permanent, qu'il s'agisse d'un parcours point à point pour un rallye ou d'un circuit fermé.\u003c\/p\u003e  \u003cp class=\"TextBoxes\"\u003eAvec plus de 4 000 circuits préchargés du monde entier, le Solo 2 DL repère sa position dès sa mise en marche. Si le circuit n'est pas préchargé, le Solo 2 en créera un nouveau. Une fois en route, il reconnaît automatiquement les coordonnées de la ligne de départ et enregistre les temps au tour à chaque passage.\u003c\/p\u003e  \u003cdiv style=\"text-align: center;\"\u003e\u003chr class=\"ProductDescription\"\u003e\u003c\/div\u003e  \u003cdiv\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Solo_2_DL_Wifi_Communication_With_PC.png?v=1614779557\"\u003e\u003c\/div\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eCommunication Wi-Fi avec le PC\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eLa Solo 2 DL intègre le Wi-Fi. Pour une analyse plus approfondie de vos données, transférez-les rapidement et en toute sécurité sur un ordinateur portable ou de bureau situé jusqu'à 50 m de distance, sans câble ni connecteur. Vous pourrez ensuite les importer dans le logiciel Race Studio 3.\u003c\/p\u003e  \u003chr class=\"ProductDescription\"\u003e  \u003cdiv\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/BikeSetSC3TrackDay-04.webp?v=1746694402\"\u003e\u003c\/div\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eExtensions compatibles\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eAjoutez des SmartyCams et une unité de contrôle Lambda pour améliorer vos performances de données.\u003c\/p\u003e  \u003chr class=\"ProductDescription\"\u003e  \u003cdiv\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\"\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Free_Download.png?v=1629297377\"\u003e\u003c\/a\u003e\u003c\/div\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eConfigure \u0026amp; Analyse avec Race Studio 3\u003c\/h2\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eConfiguration\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eAvec Race Studio 3, vous pouvez créer, modifier, supprimer, importer et exporter des configurations avec tous les canaux, pilotes ECU, canaux mathématiques, pages d'affichage, sorties numériques, alarmes, témoins de changement de vitesse et toutes les extensions nécessaires. Vous pouvez également gérer la cartographie de tous vos circuits et comparer deux tours en visionnant la vidéo enregistrée par les caméras SmartyCam HD.\u003c\/p\u003e  \u003ch3 class=\"LandingPage-CatSubTitle\"\u003eAnalyse\u003c\/h3\u003e  \u003cp class=\"TextBoxes\"\u003eAvec Race Studio 3, vous pouvez également analyser toutes les données enregistrées par Solo 2 DL et les télécharger sur votre PC : graphiques, histogrammes et tableaux vous aideront à étudier vos performances, en vous fournissant un soutien objectif pour éviter les erreurs et améliorer vos temps de course.\u003c\/p\u003e  \u003chr class=\"ProductDescription\"\u003e  \u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e  \u003ctbody\u003e  \u003ctr\u003e  \u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e  \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\"\u003e  \u003c\/a\u003e\u003c\/td\u003e  \u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e  \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e  \u003c\/a\u003e\u003c\/td\u003e  \u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e  \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e  \u003c\/a\u003e\u003c\/td\u003e  \u003c\/tr\u003e  \u003c\/tbody\u003e  \u003c\/table\u003e  \u003ch5\u003eTechnique\u003c\/h5\u003e  \u003ch3\u003e\u003ctc\u003eAim\u003c\/tc\u003e Chronomètre GPS Solo 2 DL + ECU pour course tout-terrain avec enregistreur de données\u003c\/h3\u003e  \u003cul class=\"AimProductDescriptionList\"\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eAfficher:\u003c\/strong\u003e Graphique\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eRésolution d'affichage :\u003c\/strong\u003e 238 x 99 pixels\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003ePages d'affichage :\u003c\/strong\u003e Jusqu'à 8 librement configurables\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eRétroéclairage :\u003c\/strong\u003e 8 couleurs RVB configurables\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eVoyants de changement de vitesse\/LED d'alarme :\u003c\/strong\u003e 10 LED RVB configurables\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eBase de données de pistes intégrée :\u003c\/strong\u003e Oui\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003ePlateforme inertielle :\u003c\/strong\u003e Accéléromètre interne 3 axes +5G + gyroscope 3 axes \u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eConnexion Wi-Fi :\u003c\/strong\u003e Oui\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eGPS :\u003c\/strong\u003e 25 Hz\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eConnexion à l'ECU :\u003c\/strong\u003e CAN, RS232 ou K-Line vers des milliers d'ECU leaders du secteur\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eAlimentation externe :\u003c\/strong\u003e 12 V\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cb\u003eConnecteurs : \u003c\/b\u003e1 connecteur (binder) 712, 5 broches, 1 connecteur (binder) 712, 8 broches\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eMémoire:\u003c\/strong\u003e 4 Go\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eType de batterie :\u003c\/strong\u003e Lithium rechargeable\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eBoutons-poussoirs :\u003c\/strong\u003e Métallique\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eDimensions:\u003c\/strong\u003e 98,0 x 73,7 x 30.2 mm\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003ePoids:\u003c\/strong\u003e 240 g, batterie incluse\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e  \u003cstrong\u003eÉtanche:\u003c\/strong\u003e IP67\u003c\/li\u003e  \u003c\/ul\u003e  \u003cp\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Solo_2_DL_Lap_Timer_GPS_ECU_Racing_Dash_Logger_Technical_sheet.png?v=1614778468\"\u003e\u003c\/p\u003e  \u003cp\u003e\u003cimg alt=\"Solo 2 DL Pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/solo2dl_pinout_1024x1024.png?v=1706607038\"\u003e\u003c\/p\u003e  \u003ch2\u003eBrochage TM Racing\u003c\/h2\u003e  \u003cp\u003e\u003cimg alt=\"TM Racing Pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/TM_Racing_Pinout.webp?v=1754295408\"\u003e\u003c\/p\u003e  \u003ch2\u003eOBTENIR GP1 \u0026amp; Brochage d'alimentation GET\u003c\/h2\u003e  \u003cp\u003e\u003cimg alt=\"TM Racing Pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/GET_GP1_GET_Power.webp?v=1754295407\"\u003e\u003c\/p\u003e  \u003ch2\u003eSchéma de câblage Suzuki\u003c\/h2\u003e  \u003cp\u003e\u003cimg alt=\"Suzuki pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Suzuki_pinout.webp?v=1754295407\"\u003e\u003c\/p\u003e  \u003ch2\u003eBrochage du Microtec M222\u003c\/h2\u003e  \u003cp\u003e\u003cimg alt=\"Microtec M222 pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/microtec_M222_pinout.webp?v=1754295407\"\u003e\u003c\/p\u003e  \u003ch2\u003eBrochage du Microtec M206\u003c\/h2\u003e  \u003cp\u003e\u003cimg alt=\"Microtec M206 pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/microtec_M206_pinout.webp?v=1754295407\"\u003e\u003c\/p\u003e  \u003ch2\u003eSchéma de câblage Honda\u003c\/h2\u003e  \u003cp\u003e\u003cimg alt=\"Honda pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/honda_pinout.webp?v=1754295407\"\u003e\u003c\/p\u003e  \u003ch5\u003eContenu de la boîte\u003c\/h5\u003e  \u003ch3\u003e\u003ctc\u003eAim\u003c\/tc\u003e Chronomètre GPS Solo 2 DL + ECU pour course tout-terrain avec enregistreur de données\u003c\/h3\u003e  \u003cul class=\"AimProductDescriptionList\"\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eSolo 2 DL\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eCâble d'alimentation avec adaptateur secteur\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eSupport de montage avec vis\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eManuel d'utilisation \u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003e\u003ctc\u003eAim\u003c\/tc\u003e Autocollant\u003c\/li\u003e  \u003cli\u003e\u003cstrong\u003e\u003cspan data-preserver-spaces=\"true\"\u003eChoix de câbles d'alimentation disponibles lors de la validation de votre commande. Un seul câble fourni.\u003c\/span\u003e\u003c\/strong\u003e\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eCâble d'alimentation externe CAN\/K-Line avec connecteur OBDII\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eCâble d'alimentation externe CAN\/RS232\u003c\/li\u003e  \u003cli class=\"AimProductDescriptionList\"\u003eCâble d'alimentation externe RPM (si votre véhicule n'a pas d'ECU) \u003c\/li\u003e  \u003c\/ul\u003e  \u003cp\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/SOLO_2DL_Whats_in_the_box.png?v=1617802603\"\u003e\u003c\/p\u003e  \u003ch5\u003eTéléchargements\u003c\/h5\u003e  \u003cp\u003e\u003cbr\u003e\u003c\/p\u003e  \u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e  \u003ctbody\u003e  \u003ctr\u003e  \u003ctd style=\"text-align: center;\"\u003e  \u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/solo2-solo2-dl\/Solo2DL_user_guide.pdf\"\u003e  \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"Solo 2 DL User Guide\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1590766826\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e  \u003c\/td\u003e  \u003ctd style=\"text-align: center;\"\u003e  \u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/solo2-solo2-dl\/aim_solo2-solo2dl.pdf\"\u003e  \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"Solo 2 DL Tech Sheet\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e  \u003c\/td\u003e  \u003ctd style=\"text-align: center;\"\u003e  \u003ca title=\"Aim Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimshop.com\/pages\/software-downloads\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"Aim Technologies Race Studio 3 Software Download\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e  \u003c\/td\u003e  \u003c\/tr\u003e  \u003ctr\u003e  \u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/solo2-solo2-dl\/Solo2DL_user_guide.pdf\" target=\"_blank\"\u003eGuide de l'utilisateur\u003c\/a\u003e\u003c\/td\u003e  \u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/solo2-solo2-dl\/aim_solo2-solo2dl.pdf\" target=\"_blank\"\u003eFiche technique\u003c\/a\u003e\u003c\/td\u003e  \u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"Aim Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimshop.com\/pages\/software-downloads\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e  \u003c\/tr\u003e  \u003c\/tbody\u003e  \u003c\/table\u003e","brand":"AiM Motocross","offers":[{"title":"Default Title","offer_id":31894194192486,"sku":"SOLO2","price":640.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_solo2dl_00_877ee8bd-7ce9-4160-b647-c0810ff8a00a.webp?v=1755770063","url":"https:\/\/www.aimshop.com\/fr\/products\/aim-solo-2-dl-motocross-track-day-lap-timer-kit-fr","provider":"AimShop.com","version":"1.0","type":"link"}
