Aim Solo 2 DL RPM & External Power Lead Motorcycle
SKU: SOLO-K4-L
- Prix habituel
- £42.00
- Prix habituel
- Prix de vente
- £42.00
- Prix unitaire
- par
AiM Solo 2 DL RPM & External Power Lead
The AiM PRM cable is used for vehicles when the particular ECU is not supported.
8 pin - 712 male binder connection | 3 free cables |
Suitable for Solo 2 DL | |
RPM External Power Cable
In the unlikely event, your particular ECU is not supported you can connect the Solo 2 DL to the coil RPM which will provide a digital input delivered from square wave signals or pulse signals.
This is one of the connection cables available for the Solo 2 DL. Others are the OBDII and the RS232/CAN cables.
- 8 pin - 712 male binder connection
- 2m Cable
- Red - 9-15 VDC
- Black - GND
- White - RPM
- Solo 2 DL OBDII & External power cable connector
The AiM PRM cable is used for vehicles when the particular ECU is not supported.Key Features :
In the unlikely event, your particular ECU is not supported you can connect the Solo 2 DL to the coil RPM which will provide a digital input delivered from square wave signals or pulse signals. This is one of the connection cables available for the Solo 2 DL. Others are the OBDII and the RS232/CAN cables.Expand Your System
These are some of the items that can be added to your bike for incrementing performance and data. ![]() |
- 2m Cable
- Red - 9-15 VDC
- Black - GND
- White - RPM
