Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    AiM Spark Plug Inductive RPM Adapter - AimShop.com
    MXL-RPM-IP
    Aim Spark Plug Inductive RPM Adaptor
    Dépêchez-vous 13 éléments en stock!
    £80.00
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £80.00
    The Aim RPM Adaptor has been designed for single cylinder 2 or 4-stroke engines.
    Key Features:
    • Spark plug RPM adaptor
    • Free Race Studio 3 download
    RPM Spark Plug Adaptor
    The Aim spark RPM adaptor has been designed for installation on single cylinder 2 or 4-stroke engines. It is a filter that converts the RPM signal sampled by induction from the spark plug into a square wave signal.
    The image below shows the signal sampled by induction on the left and the square wave signal on the right.
    To install the adaptr connect the plastic clip to the spark plug and the cables as follows:
    The black cable labelled GND to the device GND pin.
    The red cable is labelled 9-15 VDC to a +12V output (the battery positive pole for example).
    The blue cable labelled rpm to Aim device RPM input.
