1 de 1
Aim Water/Oil Temperature Sensor Thermo Resistor 1/8th NPT Thread
SKU: S-T-8TH
Prix ​​habituel
£70.00
Prix ​​habituel
Prix ​​de vente
£70.00
The Aim 1/8th NPT Thermo resistor temperature sensor is suitable for reading water and oil temperatures.
Suitable for water/oil temperature 4 pins 719 male binder
1/8th NPT
Aim Water Temperature Sensor Thermo Resistor 1/8th NPT Thread
The Aim oil/water (coolant) temperature sensor is fitted with a male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers. Failure to operate engine or gearbox oil within the correct temperature range can reduce efficiency, reduce power transmitted to your wheels and drastically reduce longevity.
The Thermo resistor must be put in the cooling system/oil sump.
Sensor cable length 25cm
MXS / MXP / MXG / MXL (Strada and Pista) / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, please use the 719 - 719 patch lead, which is available in various lengths from 0.5 - 3 metres. For most installations, you will need one of these leads.
AiM Water Temperature Sensor Thermo Resistor 1/8th NPT Thread
  • Temperature working range: 0-150°C (32-302°F)
  • Cable sensor length: 25cm
  • 1/8th Thermo resistor
  • 4 pins male 719 Binder connection
  • 2kΩ 1% resistor between pins 1 and 4
  • AiM Water Temperature Sensor 1/8th thread Thermo Resistor
1/8th NPT
