Aim XLog Compact Data Logger
The Aim XLog is a compact, lightweight, and waterproof data logger that records everything you need from your vehicle. With direct ECU connection, advanced GPS, built-in inertial platform, and wide expansion options, the XLog offers the same data-gathering capabilities as the Solo 2 DL, only in a smaller, screenless format that makes it perfect for motorcycles, single-seaters, or vehicles with limited cockpit space.
Why Choose the XLog Data Logger
The Aim XLog Data Logger is essentially a Solo 2 DL without the screen: offering the same logging power, precision, and expandability in a smaller, lighter package. For riders, racers, or anyone working with limited space but still demanding full-scale data analysis, the XLog is the perfect solution.
It provides a powerful solution for anyone who wants to capture and analyse their performance data without needing an on-board display. It integrates GPS lap timing, ECU data logging, acceleration and gyro measurements, and expansion support in a rugged unit that’s smaller than the palm of your hand.
AiM Accessories XLog Compact Data Logger for racing data logging
XLog datalogger on motorcycle setup
XLog Features
  • Lap times
  • Sector times
  • Vehicle position and speed
  • 3D acceleration and gyro
  • ECU data via CAN, K-Line or RS232 connections.
    (You can select the protocol of your car/bike among thousands of pre-defined protocols, or easily develop your own)
  • Digital RPM input from the primary of the coil (150-400V) or from a square wave (8-50V) when no ECU connection is available.
In addition, the XLog features a second CAN for connecting an external device or Aim Expansion, meaning you can add a Lambda Controller, analogue inputs, and a professional motorsport camera for enhanced functionalities.
X Log GPS & Inertial Platform Graphic
  • Lap Timing & Sectors: Automatically recognises track layouts, samples laps and sectors, and provides all the raw data for Race Studio 3 analysis.
X Log Connectivity graphic
XLog Connectivity
  • ECU Connection: Supports thousands of predefined CAN, RS232, or K-Line protocols, or you can build your own protocol via CAN builder.
  • Second CAN Option: Configure for Aim expansions, or connect additional sensors and third-party CAN devices.
  • Wireless: Integrated Wi-Fi and Bluetooth for fast, cable-free data transfer.
  • USB-C & Memory Key: 4GB internal memory plus a removable 16GB USB-C key for quick access.
Compact, Durable Design
X Log data analysis with Race Studio 3 graphic
Analyse with Race Studio 3
Expand your X Log's capabilities with the ACC Analogue CAN Converter, the LCU-One Lambda Controller, the SmartyCam 3, the Data Hub and more.
The XLog Data Logger works seamlessly with Aim’s ecosystem of devices thanks to its second CAN connection.
The second CAN option can be used for Aim Expansions or to connect sensors and other devices that communicate via CAN and use existing protocols or create a dedicated protocol for the second CAN.
  • ACC3 Analogue to CAN Converter: Add up to four analogue channels for pressure, temperature, suspension, and other sensors.
  • LCU-One Lambda Controller: Capture air/fuel ratios and exhaust data for tuning and performance optimisation.
  • Data Hub: Split EXP ports to connect multiple expansions such as GS-Dash displays, Lambda controllers, or additional converters.
  • USB Connection: Yes
  • GPS: 25Hz
  • Wi-Fi: Built-in
  • Bluetooth: Built-in
  • Expansions: ACC3, Lambda Sensors, SmartyCam
  • RPM Input: 1
  • Push Button: 1
  • Status LED: 1
  • External Power: 9-15V
  • Connectors: 5-pin binder 712, 8-pin binder 712, USB Type-C
  • Memory: 4GB internal + removable USB Type-C memory key
  • Material: PA6 30% glass fibre reinforced
  • Weight: 150g approx.
SKU: XLOG
XLog User Guide
XLog Tech Sheet
XLog Data Logger
ECULog Data Logger
EVO6 Data Logger
EVO6L Data Logger
  • Compact & Lightweight
  • Built-In GPS
  • Screenless Design
  • ECU Connection
  • Optional GPS
  • Screenless Design
  • ECU Connection
  • GPS Module (Included)
  • Screenless Design
  • ECU Connection
  • CAN Output
  • 8 Analogue Inputs
  • 2 Digital Outputs
  • Wi-Fi & Bluetooth Connectivity
  • Screenless Design
  • ECU Connection
  • CAN Output
  • 5 Analogue Inputs
  • 1 Digital Output
  • Dimensions: 61.4 x 44.7 x 27.2mm
  • Weight: 100g approx.
  • Dimensions: 114.4 x 47.2 x 26.0mm
  • Weight: 230g approx.
  • Dimensions: 130.0 x 46.6 x 26.0mm
  • XLog
  • Mini USB Drive 16GB
  • Harness
  • USB A to USB C Cable
  • ECULog
  • Harness
  • EVO6
  • Chosen GPS Module
  • Harness
  • USB to 719 Adaptor
  • Mini USB-USB Cable
  • EVO6L
  • Chosen GPS Module
  • Chosen Connection Cable
  • EVO Power Cable
  • 712 to USB Cable
  • GPS: 25Hz
  • Wi-Fi: Built-in
  • RPM Input: 1
  • Push Button: 1
  • Status LED: 1
  • Battery Life: Up to 10 hours
  • Material: PA6 GS30% glass fibre reinforced
  • ECU Connections: CAN, RS232 or K-Line to 1,000+ industry leading ECUs
  • Expansions: GPS09/GPS09 Pro, ACC3, Lambda Sensors, SmartyCam
  • Connectors: 5-pin binder 712, 7-pin binder 712, USB Type-C
  • Memory: 4GB + removable USB Type-C memory key
  • Inertial Platform: Internal 3 axis ±5G accelerometer + 3 axis gyro
  • Analogue Inputs: 8 fully configurable: 0-5V, 0-12V, K thermocouples, max freq. 1,000Hz each
  • Digital Inputs: Coil RPM and 4 speed inputs
  • Digital Outputs: 2, up to 1 Amp each
  • Second CAN: Yes
  • Wi-Fi Connection: Yes
  • Bluetooth: Yes
  • ECU Connections: CAN, RS232 or K-Line to +2,000 industry-leading ECUs
  • Expansions: GPS09, Lambda Sensors, SmartyCam
  • Status LED: 1
  • Connectors: 2 motorsport connectors
  • Memory: 4GB internal + removable SD memory card
  • SD Card: Internal, up to 128GB
  • Material: Anodised Aluminium
  • Analogue Inputs: 5 fully configurable, max freq. 1,000Hz each
  • Digital Inputs: 2 speed inputs, lap signal, coil RPM input
  • Digital Output: 1, up to 1 Amp
  • Status LED: 1
  • Connectors: 13 712 female Binder connectors
  • Displays sold separately
