M-Sport Ford Fiesta Rally 2 Aim SmartyCam 3 GP Kit - MK2 from 2022
SKU: FORD-SM3-GP-SM-EM-CAN-4 /
- Prix habituel
£1,500.00£1,800.00(inc VAT)
- Prix habituel
- Prix de vente
- £1,500.00
- Prix unitaire
- par
Mount Anywhere, Stream Anytime
Enhance your M-Sport Ford Fiesta Rally 2's performance with the AiM SmartyCam 3 GP Kit, specifically designed for Mk2 models from 2022.
The all-NEW SmartyCam 3 GP camera has been designed for motorsport with a single purpose:
To provide great videos and supply you with all the information you need.
SmartyCam 3 GP camera overlays all the data from both GPS and AiM loggers connected to your ECU. Full HD camera system, Video output, CAN connection, USB-C connection, and GPS port are only a few of the features of SmartyCam 3 GP: the power of simplicity.
The new SmartyCam 3 GP saves all your information to a supported micro-SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 automatically powers on and off with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, and lap & split times. The format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 2.4” 240x320 pixels gives your footage crisp condition. Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection.
Differences between the Standard and Pro Model
Internal Memory:
SmartyCam 3 GP: Stores video data exclusively on an SD card, supporting capacities up to 2TB.
SmartyCam 3 GP Pro: In addition to SD card storage, it features a 64GB internal EMMC storage that operates on a loop recording basis, overwriting the oldest files when full.
Connectors:
SmartyCam 3 GP: Equipped with standard connectors for power, data, and video output.
SmartyCam 3 GP Pro: Includes two AS Micro Xtra Lite Deutsch connectors, offering enhanced durability and reliability in professional racing environments.
Supported Models and years
M-Sport Ford Fiesta Rally 2 Mk2from 2022
If specifically set by M-Sport, these models feature a CAN data bus accessible to AiM devices through a Deutsch DTM06-2S connector located by/behind the co-driver’s foot plate, labelled CAN3.
The SmartyCam 3 GP includes a global shutter CMOS sensor and a low distortion lens with a field of view of 67°, 84° or 120° covering all areas, its lightweight 200g (battery included) framework infallible in providing you with smooth and effortless footage.
The SmartyCam 3 GP contains a rechargeable lithium battery confined inside its (main) 120.8x80.2x30.9mm (bullet) 24diamx48.2mm body, and using its connectors - 2 Binder 712 female connectors + 2 SMA female connectors (see pinout page) + 1 USB-C - slots right into the back of your dashboard.
Finished with a sleek anodised aluminium coat, the SmartyCam 3 GP is assured to add efficiency, informational data, productivity, and style to your racing. AiM SmartyCam 3 GP has the ability to mount onto many aspects of your vehicle for easier accessibility. Here at AiM, we provide only the best innovations and are constantly and consistently working to better your racing experience.
SD cards sold separately.
The SmartyCam 3 GP Kit seamlessly integrates with the M-Sport Ford Fiesta Rally 2 Mk2's ECU, providing real time data overlays for enhanced performance analysis. The SmartyCam 3 GP kit can be connected through the CAN network to our AiM Loggers, MX Series, MXL2, MyChron, Solo2 DL, EVO5 and ECU Bridge.
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Connectors: 2 Binder 712 female connectors + 2 SMA female connector (see pinout page) + 1 USB-C
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Body: Anodised Aluminium
- Dimensions: Main unit 120.8 x 80.2 x 30.9 mm | Bullet camera 24 diam x 46.0 mm (120° lens) | Bullet camera 24 diam x 41.0 mm (67°-84° lens)
- Bullet Cable Length: From 0.5 m to 4 m (7 lengths available)
- Weight: Main Body - 320g, Bullet Camera - 45g
- Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for M-Sport Ford Fiesta Rally 2 drivers
Channels received by AiM devices configured with Ford M-Sport 22 protocol are:
Channel Name | Function |
RPM | RPM |
Vehicle Speed | Vehicle speed |
Gear FIA | Engaged gear |
Steering Wheel | Steering wheel angle position |
Pedal Pos | Throttle pedal position |
Brake Press Fr | Front brake pressure |
Brake Press Rr | Rear brake pressure |
Turbo Speed | Turbo speed |
Engine Cool Temp | Engine coolant temperature |
Engine Oil Temp | Engine oil temperature |
Air Charge Temp | Air charge temperature |
Exhaust Temp | Exhaust gas temperature |
Oil Pressure | Oil pressure |
MAP | Manifold air pressure |
ALS Cal | Anti lag system calibration |
- Your choice of either SmartyCam 3 GP or SmartyCam 3 GP Pro
USB-C Cable
2m CAN Cable
712 5 Pin Male
Internal Memory:SmartyCam 3 GP: Stores video data exclusively on an SD card, supporting capacities up to 2TB.
Connectors:
Technical Specifications
- Video Out: 3G-SDI
“Ford M-Sport 22” Protocol
RPM | RPM |
Whats in The Box
USB-C Cable
2m CAN Cable
712 5 Pin Male
