Honda CBR 600RR & 1000RR AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-HON - V0256929CS - X47SOLO2DL02
- Prix habituel
- £620.00
- Prix habituel
- Prix de vente
- £620.00
- Prix unitaire
- par
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Honda this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide | Honda ECU connection cable |
This kit has been specifically designed for Honda bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Honda ECU will give you all the engine performance information you need to help improve your driving performance.
CBR 600RR - 2003-2019 | CBR 600RR HRC with D11 marked ECU - 2013-2015 |
CBR 1000RR - 2004-2016 | CBR 1000RR HRC - 2014-2016 |
Please Note: The bracket is only compatible with CBR 600RR original triple plate.
The Honda ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
- Display: Graphical
- Inertial platform : Internal 3 axis +5G accelerometer + 3 axis gyro +3 axis magnetometer
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
Below is the pinout drawing for the Honda 600RR, 1000RR plug & play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- User manual
- AiM Honda Connection Cable
- Bracket
- 1 washer
- 1 Allen screw with rounded head M6 x 60
- 1 rubber dowel
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Honda this kit will ensure an improvement in your driving performance.Key Features :
This kit has been specifically designed for Honda bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Honda ECU will give you all the engine performance information you need to help improve your driving performance.Plug & Play
The Honda ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated.
- GPS: 10 Hz
- Memory: 4 GB
360° View
- Solo 2 DL
- User manual
- Bracket
- 1 washer
- 1 rubber dowel
