1 de 6
Hyundai i20 N Rally2 BC3N Aim SmartyCam 3 Dual Kit from 2021
SKU: HYUNDAI-Rally-SM3-D
Prix ​​habituel
£1,660.00
Prix ​​habituel
Prix ​​de vente
£1,660.00
Enhance your Hyundai i20 N Rally2's performance with the AiM SmartyCam 3 Dual Kit, specifically designed for models from 2021. Engineered for any racer who wants to get the most out of any performance video on the track, the SmartyCam 3 Dual is the flagship version of SmartyCam 3 range.
Dual Full HD camera system, Video output, CAN connection, USB-C connection, Ethernet port are only few of the features of SmartyCam 3 Dual: the most powerful of our range.
The new SmartyCam 3 Dual saves all your information to a supported SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 Dual automatically powers on and off in-sync with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, lap & split times. Video format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 2.4” 240x320 pixels gives your footage crisp condition.
Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection.
hyundai i20 Rally2 BC3n
Supported Models and years
  • Hyundai i20 N Rally2 (BC3N)
    from 2021
The CAN driver developed to communicate with this vehicle, is accessible through the Main_24-Camera connector, a Deutsch DTM06-6P located on the central tunnel next to the fuel tank wall.
smartycam icon
Video Output/Streaming
SmartyCam 3 Dual features a video output with SD interface. It allows you to send the video/audio directly to wherever you choose, for example your pit crew, at 30 or 60fps.
Two Video Inputs
Picture in Picture
smartycam icon
With the built-in data logger, you can view all the channels displayed on the video footage and review them with our new Race Studio 3 analysis software. Such channels include RPM, throttle, engaged gears, acceleration, temperatures, and pressures including a tri-axis accelerometer measuring 16G.
smartycam icon
Standalone Feature
The SmartyCam 3 Dual provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however, we have also equipped the SmartyCam 3 Dual with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Dual through the CAN/ECU connections of your choosing.
smartycam icon
Quality
smartycam icon
Anatomy
smartycam icon
Higher Storage Capacity
Generic HD cameras focus too much on pixel numbers resulting in large file sizes. The SmartyCam 3 footage has the same quality as other FHD cameras with smaller files due to H.264 compression system parameters being optimised to a perfect balance between video quality and file size. Choose between three file quality levels: One hour recording = 4GB (High Quality), 2GB (Normal Quality) or 1.5GB (Lower quality).
SD cards sold separately.
smartycam icon
The SmartyCam 3 Dual Kit seamlessly integrates with the Hyundai i20 N Rally2's ECU, providing real time data overlays for enhanced performance analysis. The SmartyCam 3 Dual can be connected through the CAN network to our AiM Loggers, MX Series, MXL2, MyChron, Solo2 DL, EVO5 and ECU Bridge.
smartycam icon
Upgrade your Hyundai i20 N Rally2 with the AiM SmartyCam 3 Dual Kit today and experience unparalleled data insights for yourself!
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for Hyundai i20 N Rally2 drivers
smarty cam 3 sport connectors
smartycam3 dual pinout
Channels received by AiM devices configured with Hyundai i20 N Rally2 BC3N protocol are:
Channel Name Function
RPM ACVCam RPM (specific for video recording activation)
Gear Position Engaged gear
Vehicle Speed Vehicle speed
Front Brk Press Front brake pressure
Rear Brk Press Rear brake pressure
Hand Brk Press Handbrake pressure
Steering Angle Steering wheel angle
Throttle Pedal Throttle pedal position
StDrvgMode Status driving mode
  • SmartyCam 3 Dual
  • External Power Cable
  • USB-C Cable
  • 2 Bullet Cameras
  • 2 Co Ax Cables
  • Complete CAN / RS232 & Expantion With Ethernet Connection & External Mic Harness
    from 2021
smartycam icon
Two Video Inputs
Picture in Picture
smartycam icon
smartycam icon
Standalone Feature
smartycam icon
Quality
smartycam icon
Anatomy
smartycam icon
smartycam icon
smartycam icon
Technical Specifications
  • Video Out: 3G-SDI
Hyundai i20 N Rally2 BC3N Protocol
What's In The Box
  • SmartyCam 3 Dual
  • USB-C Cable
  • 2 Bullet Cameras
  • 2 Co Ax Cables
