{"product_id":"super-b-bci-battery-communication-interface-nomia-nomada","title":"Interface de communication de batterie Super B (BCI)","description":"\u003cstyle\u003e\n    .section-dark-bg {\n      margin-top: 50px;\n      padding: 50px 20px;\n    }\n    .performance-box {\n      background-color: #263c44;\n      padding: 20px;\n      display: flex;\n      flex-direction: column;\n      justify-content: center;\n      align-items: center;\n      width: 150px;\n      max-width: 150px;\n      color: white;\n      text-align: center;\n    }\n    .performance-box p {\n      margin-bottom: 0;\n      font-size: 15px;\n      line-height: 19px;\n    }\n    .box-container {\n      display: flex;\n      gap: 20px;\n      flex-wrap: wrap;\n      justify-content: center;\n    }\n    .features-container {\n      margin-top: 50px;\n      display: flex;\n      gap: 20px;\n      flex-wrap: wrap;\n      display: flex;\n      gap: 20px;\n      flex-wrap: wrap;\n      align-items: center;\n      justify-content: center;\n    }\n  \n    .container {\n      display: flex;\n      flex-wrap: wrap;\n      justify-content: space-between;\n      margin-top: 50px;\n    }\n  \n    .superb-section {\n      flex-basis: calc(\n        50% - 20px\n      ); \/* Adjust the 20px to control the gap between sections *\/\n      box-sizing: border-box;\n      margin-bottom: 20px; \/* Space between sections vertically *\/\n      padding: 20px;\n      border: 1px solid #cbcbcb;\n      border-radius: 0.75rem;\n    }\n    .superb-section h4 {\n      font-size: 26px;\n      font-weight: 600;\n      color: #263c44;\n      margin-top: 0;\n    }\n  \n    .superb-row {\n      display: flex;\n      margin-bottom: 5px; \/* Space between rows *\/\n    }\n  \n    .superb-title,\n    .superb-spec {\n      flex: 1;\n      font-size: 14px;\n    }\n    .superb-spec {\n      color: #66767c;\n    }\n    .certs-container {\n      margin-top: 50px;\n      display: flex;\n      gap: 10px;\n      flex-wrap: wrap;\n    }\n    .certs-container img {\n      opacity: 0.4;\n    }\n    .sq-cont {\n      display: flex;\n      flex-direction: column;\n      align-items: center;\n    }\n    .downloads-container {\n      margin-top: 50px;\n      display: flex;\n      justify-content: space-around;\n      flex-wrap: wrap;\n      gap: 20px;\n      width: 100%;\n    }\n    .download-item {\n      display: flex;\n      flex-direction: column;\n      align-items: center;\n    }\n    \/* Responsive design for mobile *\/\n    @media (max-width: 768px) {\n      .superb-section {\n        flex-basis: 100%;\n      }\n    }\n  \u003c\/style\u003e      \u003cdiv style=\"display: flex; justify-content: center;\"\u003e\u003cimg alt=\"superb lithium batteries\" height=\"167\" width=\"392\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/superbLogo.png?v=1710418318\"\u003e\u003c\/div\u003e      \u003ch3 style=\"text-align: center; color: #263c44; font-size: 28px; font-weight: 600;\" class=\"oaimY _1ntuX\"\u003eBCI\u003c\/h3\u003e      \u003cp\u003e\u003cspan\u003eL'interface de communication de batterie (BCI) est un dispositif qui collecte des données provenant de plusieurs batteries au lithium Super B et les représente comme un seul système de batterie.\u003c\/span\u003e\u003c\/p\u003e      \u003cdiv class=\"features-container\"\u003e          \u003cul\u003e              \u003cli style=\"list-style: none\"\u003e                  \u003ch3 style=\"color: #263c44; font-size: 28px; font-weight: 600\"\u003e           Caractéristiques du produit         \u003c\/h3\u003e              \u003c\/li\u003e          \u003cli\u003eContrôle de la fonction de précharge. Par conséquent, un contacteur supplémentaire est nécessaire.\u003cbr\u003e et une résistance adaptée à l'application est nécessaire\u003c\/li\u003e          \u003cli\u003eConversions de protocole (en fonction de la version du logiciel BCI)\u003c\/li\u003e          \u003cli\u003eContrôle du chargeur par CAN ou par signal d'activation de charge (selon la version du logiciel BCI)\u003c\/li\u003e          \u003cli\u003eGérer les éléments chauffants des batteries Super B Li-ion équipées d'éléments chauffants\u003c\/li\u003e          \u003c\/ul\u003e          \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/2530-SB_BCI.jpg?v=1710498731\" alt=\"AiM Shop Youtube Channel Product Videos - AiM Technologies - AiM Academy\"\u003e      \u003c\/div\u003e      \u003cdiv class=\"intended-cont\"\u003e              \u003ch3 style=\"color: #263c44; font-size: 28px; font-weight: 600\"\u003e           Utilisation prévue         \u003c\/h3\u003e                  \u003cp\u003e             Les applications potentielles de l'utilisation du BCI en combinaison avec des batteries Li-ion de Super B sont les suivantes :\u003cbr\u003e             • Applications hors réseau\u003cbr\u003e             • Applications marines\u003cbr\u003e             • Support de stockage d'énergie (renouvelable) (traction)\u003cbr\u003e             • Batterie pour véhicules.\u003cbr\u003e                          \u003cbr\u003e\u003cbr\u003e             Selon l'application, il peut être nécessaire d'utiliser des composants supplémentaires pour garantir la conformité de l'installation aux réglementations en vigueur. Voir le chapitre 5.6 pour plus d'informations sur les installations électriques.\u003cbr\u003e\u003cbr\u003e             Le BCI est vendu comme un appareil unique ; il incombe au client de se procurer les composants nécessaires à la protection des batteries Li-ion. Super B décline toute responsabilité quant aux installations effectuées par le client.\u003cbr\u003e\u003cbr\u003e             Super B propose également la fourniture d'une installation complète. Il peut s'agir d'une solution standard ou d'une solution personnalisée. La solution standard est disponible sur notre site web ou auprès de notre service commercial. La solution personnalisée doit être définie en collaboration avec votre interlocuteur commercial et votre ingénieur d'application.\u003cbr\u003e\u003cbr\u003e             Si ce manuel ne couvre pas ou ne traite pas de votre application, veuillez contacter Super B. Seul le personnel qualifié peut installer et effectuer la maintenance du système complet - reportez-vous toujours au chapitre 1 de ce manuel pour les consignes de sécurité.\u003cbr\u003e\u003cbr\u003e             Les limites d'utilisation du BCI, telles que décrites dans ce manuel, doivent toujours être respectées. Le BCI ne doit pas être utilisé à des fins médicales ou aéronautiques. Son utilisation est strictement limitée aux fins décrites dans ce manuel. Toute autre utilisation sera considérée comme inappropriée et annulera la garantie du produit. Super B décline toute responsabilité en cas de dommages causés par une utilisation inappropriée, incorrecte ou imprudente du produit. Veuillez lire attentivement et comprendre l'intégralité de ce manuel avant d'utiliser le produit.         \u003c\/p\u003e      \u003c\/div\u003e        \u003ch5\u003eApplication mobile\u003c\/h5\u003e      \u003cdiv style=\"margin-top: 50px;\"\u003e      \u003ch3 style=\"color: #263c44; margin: 0; margin-bottom: 20px; font-size: 28px; font-weight: 600;\"\u003ePrenez le contrôle - Logiciels et applications\u003c\/h3\u003e      \u003cp\u003eSuper B propose le logiciel Be In Charge, permettant de lire les données du système de gestion de batterie (BMS) interne. Ce logiciel utilise un convertisseur CAN vers USB pour se connecter à l'interface de communication. Il est capable de lire l'état actuel de la batterie et de ses cellules, ainsi que des informations statistiques. Be In Charge permet également de mettre à jour le firmware de la batterie Li-ion. Le logiciel et le matériel Be In Charge ne sont pas inclus avec la batterie Li-ion. Super B propose également l'application Be In Charge pour appareils mobiles Android et iOS, disponible sur le Google Play Store et l'App Store.\u003c\/p\u003e      \u003cimg alt=\"superb app\" height=\"150\" width=\"137\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/codescan.png?v=1710425607\" style=\"margin-top: 20px;\"\u003e  \u003c\/div\u003e    \u003ch5\u003eTéléchargements\u003c\/h5\u003e  \u003cdiv class=\"downloads-container\"\u003e      \u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/manual_bci_en_v1-2.pdf?v=1710499117\"\u003e          \u003cdiv class=\"download-item\"\u003e              \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1590766826\"\u003e       Manuel d'utilisation     \u003c\/div\u003e      \u003c\/a\u003e      \u003cdiv class=\"download-item\"\u003e          \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e     Fichier CAO   \u003c\/div\u003e  \u003c\/div\u003e","brand":"Super B","offers":[{"title":"Default Title","offer_id":40874289266790,"sku":"BCI","price":252.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_superBBCI_01.png?v=1773662307","url":"https:\/\/www.aimshop.com\/fr\/products\/interface-de-communication-batterie-super-b-bci-nomia-nomada","provider":"AimShop.com","version":"1.0","type":"link"}
