{"product_id":"super-b-be-in-charge-monitoring-kit","title":"Kit de surveillance Super B Be In Charge","description":"\u003cp style=\"display: none\"\u003eLe kit de surveillance Super B Be In Charge fournit des informations importantes sur l'état et l'utilisation de la batterie afin de détecter d'éventuels problèmes. Il est compatible avec les modèles Nomia et Nomada. \u0026amp; Piles Epsilon\u003c\/p\u003e\u003cstyle\u003e\n  .LandingPage-CatTitle {\n        font-size: 24px;\n        text-align: center;\n      font-weight:600;\n    }\n  .LandingPage-CatSubTitle {\n        font-size: 22px;\n        text-align: center;\n      margin:0;\n      font-weight:600;\n    }\n    .TextBoxes {\n        font-size: 20px;\n        line-height: 32px;\n        text-align: center;\n    }\n  hr {\n    border: none;\n    height: 0.1rem;\n    background-color: rgba(var(--color-foreground), 0.2);\n    display: block;\n    margin: 5rem 0;\n}\n  .performance-box {\n    background-color: #999;\n    padding: 20px;\n    display: flex;\n    flex-direction: column;\n    justify-content: center;\n    align-items: center;\n    width: 150px;\n    max-width: 150px;\n    color: white;\n    text-align: center;\n  }\n  .performance-box p {\n    margin-bottom: 0;\n    font-size: 15px;\n    line-height: 19px;\n  }\n  .box-container {\n    display: flex;\n    gap: 20px;\n    flex-wrap: wrap;\n    justify-content: center;\n  }\n  .features-container {\n    margin-top: 50px;\n    display: flex;\n    gap: 20px;\n    flex-wrap: wrap;\n    display: flex;\n    gap: 20px;\n    flex-wrap: wrap;\n    align-items: center;\n    justify-content: center;\n  }\n\n  .container {\n    display: flex;\n    flex-wrap: wrap;\n    justify-content: space-between;\n    margin-top: 50px;\n  }\n\n  .superb-section {\n    flex-basis: calc(\n      50% - 20px\n    ); \/* Adjust the 20px to control the gap between sections *\/\n    box-sizing: border-box;\n    margin-bottom: 20px; \/* Space between sections vertically *\/\n    padding: 20px;\n    border: 1px solid #cbcbcb;\n    border-radius: 0.75rem;\n  }\n  .superb-row {\n    display: flex;\n    margin-bottom: 5px; \/* Space between rows *\/\n  }\n\n  .superb-title,\n  .superb-spec {\n    flex: 1;\n    font-size: 14px;\n  }\n  .superb-spec {\n    color: #999;\n  }\n.certs-container{\n    margin-top: 50px;\n    display:flex;\n    gap:10px;\n  flex-wrap:wrap;\n      justify-content: center;\n}\n  .certs-container img {\n    opacity: 0.4;\n  }\n  .sq-cont {\n    display: flex;\n    flex-direction: column;\n    align-items: center;\n  }\n  .downloads-container {\n    margin-top: 50px;\n    display: flex;\n    justify-content: space-around;\n    flex-wrap: wrap;\n    gap: 20px;\n    width: 100%;\n  }\n  .download-item {\n    display: flex;\n    flex-direction: column;\n    align-items: center;\n  }\n  \/* Responsive design for mobile *\/\n  @media (max-width: 768px) {\n    .superb-section {\n      flex-basis: 100%;\n    }\n    .LandingPage-CatTitle {\n            font-size: 22px;\n        }\n    .LandingPage-CatSubTitle {\n            font-size: 20px;\n        }\n        .TextBoxes {\n            font-size: 18px;\n            line-height: 32px;\n        }\n  }\n\u003c\/style\u003e  \u003cdiv style=\"display: flex; justify-content: center;\"\u003e\u003cimg alt=\"Super B Lithium Battery Accessories\" height=\"167\" width=\"392\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/superbLogo.png?v=1710418318\"\u003e\u003c\/div\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eQu'est-ce que le kit de surveillance Be In Charge ?\u003c\/h2\u003e  \u003cp class=\"TextBoxes\"\u003eLe kit de surveillance Super B Be In Charge fournit des informations importantes sur l'état et l'utilisation de la batterie, vous permettant ainsi de détecter facilement d'éventuels problèmes.\u003c\/p\u003e  \u003chr\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003eBatteries compatibles\u003c\/h2\u003e  \u003cp class=\"TextBoxes\"\u003eLe kit de surveillance de batterie standard est compatible avec \u003ca title=\"Super B Nomia 12V210Ah Battery\" href=\"https:\/\/www.aimshop.com\/products\/super-b-nomia-12v210ah-lithium-traction-battery\"\u003eNomia 12V210Ah\u003c\/a\u003e \/ \u003ca title=\"Super B Nomia 12V340Ah Battery\" href=\"https:\/\/www.aimshop.com\/products\/super-b-nomia-12v340ah-lithium-traction-battery\"\u003e12V340Ah\u003c\/a\u003e, \u003ca title=\"Super B Nomada 12V105Ah Battery\" href=\"https:\/\/www.aimshop.com\/products\/super-b-nomada-12v105ah-lithium-traction-battery\"\u003eNomada\u003c\/a\u003e, \u003ca title=\"Super B Battery Interface Box\" href=\"https:\/\/www.aimshop.com\/products\/super-b-battery-interface-box-bib\"\u003eBoîtier d'interface de batterie\u003c\/a\u003e et \u003ca title=\"Battery Communication Interface\" href=\"https:\/\/www.aimshop.com\/products\/super-b-bci-battery-communication-interface-nomia-nomada\"\u003eInterface de communication de la batterie\u003c\/a\u003e.  Le kit de surveillance lumineux Be In Charge est uniquement compatible avec \u003ca title=\"Super B Epsilon 12V100Ah Battery\" href=\"https:\/\/www.aimshop.com\/products\/super-b-epsilon-12v100ah-lithium-traction-battery\"\u003eEpsilon 12V 100Ah\u003c\/a\u003e \/ \u003ca title=\"Super B Epsilon 12V150Ah Battery\" href=\"https:\/\/www.aimshop.com\/products\/super-b-epsilon-12v150ah-lithium-traction-battery\"\u003e12V 150Ah\u003c\/a\u003e piles.\u003c\/p\u003e  \u003ch5\u003eApplication mobile\u003c\/h5\u003e  \u003cdiv style=\"margin-top: 50px;\"\u003e  \u003ch2 style=\"color: #999; margin: 0;\" class=\"LandingPage-CatTitle\"\u003ePrenez le contrôle - Logiciels et applications\u003c\/h2\u003e  \u003cp class=\"TextBoxes\"\u003eSuper B fournit le logiciel Be In Charge, permettant de lire les données du système de gestion de batterie (BMS) interne. Ce logiciel utilise un convertisseur CAN vers USB pour se connecter à l'interface de communication. Il est capable de lire l'état actuel de la batterie, notamment la tension et la température des cellules, ainsi que des informations statistiques. Le logiciel Be In Charge permet également de mettre à jour le firmware de la batterie Li-ion. Le logiciel et le matériel Be In Charge ne sont pas inclus avec la batterie Li-ion. Super B propose également une application Be In Charge pour appareils mobiles Android et iOS, disponible sur le Google Play Store et l'App Store d'Apple.\u003c\/p\u003e  \u003cdiv style=\"margin: 0 auto; width: fit-content;\"\u003e\u003cimg alt=\"Super B App Software\" height=\"150\" width=\"137\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/codescan.png?v=1710425607\"\u003e\u003c\/div\u003e  \u003c\/div\u003e","brand":"Super B","offers":[{"title":"Default Title","offer_id":40874212130918,"sku":"BICMK","price":400.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_beInChargeMonitoringKit_00_cb8c515c-135d-40b0-aebb-dcd58828f792.png?v=1773662479","url":"https:\/\/www.aimshop.com\/fr\/products\/kit-de-surveillance-super-b-be-in-charge","provider":"AimShop.com","version":"1.0","type":"link"}
