{"product_id":"link-can-lambda","title":"Link CAN Lambda","description":"\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Link_Banner_Description.png?v=1616071775\" style=\"width: 100%;\"\u003e\u003c\/p\u003e\n\u003ch3\u003eLink CAN Lambda\u003c\/h3\u003e\n\u003cp\u003eLink’s CAN Lambda is an easy to use CAN module that provides digital wideband sensor control via CAN bus and is compatible with leading aftermarket ECUs. \u003cbr\u003e\u003cbr\u003eIf using the CAN Lambda with a G4+\/G4X PlugIn ECU use a Link CANPCB cable to access the CAN port on the PlugIn PCB and a Link CANF field insertable CAN plug.\u003cbr\u003e\u003cbr\u003ePlease note proper CAN protocol must be followed. \u003c\/p\u003e\n\u003cp\u003eThe CAN-Lambda’s ability to measure the proportion of oxygen in exhaust gases makes it an essential tool for accurately tuning fuel mixtures as well as allowing your ECU to make tuning adjustments \u003cbr\u003eon the fly. \u003cbr\u003e\u003cbr\u003eBeing fully digital the CAN Lambda’s powerful LSU 4.9 sensor will eliminate any loss of signal, risk, delays and errors that analogue alternatives cause. The CAN-Lambda never requires free-air calibration.\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003e\u003c\/h3\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003cp\u003e\u003cstrong\u003eDimensions\u003c\/strong\u003e\u003cbr\u003eEnclosure 60 x 26 x 15mm\u003cbr\u003eLead length 170mm\u003cbr\u003eWeight 70g\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eInput Voltage\u003c\/strong\u003e\u003cbr\u003eController 7.5 - 20 V\u003cbr\u003eSensor 10.8 - 16.5 V\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eInput Current\u003c\/strong\u003e\u003cbr\u003eController 100 mA\u003cbr\u003eSensor Heater 8 A\u003c\/p\u003e\n\u003cp\u003eOperating Temp -20 - 100 deg.C\u003cbr\u003eSensor Bosch LSU4.9\u003cbr\u003eSensing Range 0.67 - 10 lambda\u003c\/p\u003e\n\u003cp\u003eCAN Frequency 1Mb\/s,500kb\/s,250kb\/s,125kb\/s\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eLink CAN Lambda\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eCAN-Lambda Device\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eBosch LSU 4.9 Sensor\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eDeutsch 4-way Connector Kit\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e02 Bung and Plug\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e2 Large Stickers\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e2 Small Stickers\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eQuick Start Guide\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cbr\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimshop.com\/pages\/pc-link-downloads\" title=\"PC Link Downloads\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/PC_LINK_Downloads.png?v=1616072312\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimshop.com\/pages\/pc-link-downloads\" title=\"PC Link Downloads\" target=\"_blank\"\u003e \u003cspan style=\"color: #088cf7;\"\u003ePC Link Downloads\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Link","offers":[{"title":"Default Title","offer_id":39292988096614,"sku":"CANLAM","price":310.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/products\/LinkCANLambda.png?v=1617980640","url":"https:\/\/www.aimshop.com\/fr\/products\/link-can-lambda","provider":"AimShop.com","version":"1.0","type":"link"}
