MV Agusta F3 & F4 AiM Solo 2 DL & SmartyCam 2.2 GP HD Motorcycle Plug & Play Lap Timer Track Day Kit
SKU: SM-CAM-GP-2 - SOLO2-K-MV - SM-GPC - V02569310 - X47SOLO2DL02 - XB1SGPH22B67L200
- Prix habituel
- £1,570.00
- Prix habituel
- Prix de vente
- £1,570.00
- Prix unitaire
- par
MV Agusta F3 & F4 AiM Solo 2 DL + SmartyCam 2.2 GP HD Motorcycle Plug & Play Lap Timer Track Day Kit
The MV Agusta plug & play kit combined with the Solo 2 DL and SmartyCam GP HD gives you the ultimate track day experience.
Database with more than 4,000 tracks worldwide | MV Agusta ECU connection cable |
This ultimate track day kit has been specifically designed for MV Agusta bikes. The kit includes a plug & play interface cable for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam GP HD to record your races and provide all the technical layovers to help improve your performance. Also added is our GP HD bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your MV Agusta ECU will give you all the engine performance information you need to help improve your driving performance.
SmartyCam GP HD 2.2 Features:
The plug & play cable currently fits the following MV Agusta bike models:
F3 675 - From 2012 | F3 800 - From 2012 |
F4 1000 - From 2013 |
Powerful Combination
The MV Agusta ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
With the added SmartyCam GP HD 2.2 camera you create an even more powerful system to help provide great videos that include all the technical information to help improve your performance.
The SmartyCam GP HD has four connections, one that is completely dedicated to the bullet cam, one for the ECU-MIC, one for a GPS Module connection and EXP to connect to the Solo 2 DL.
SmartyCam GP HD 2.2
The AiM SmartyCam GP HD 2.2 has been engineered to provide great videos and overlay all the technical data you want to see to help improve your performance while racing. The SmartyCam GP HD is used worldwide, giving racers on circuits, open course or road racing fantastic high definition, high frame rate videos with all the data overlayed to help improve your performance. It's easy to install, robust, reliable and can withstand the extreme working conditions expected by the track or road.
The SmartyCam GP HD 2.2 has a wide TFT colour display. Intelligent settings allow the camera to automatically start/stop recording by using the inbuilt 3 axis accelerometer, so you can concentrate on the track and not the camera, and immediate playback helps with setting up.
The Bullet is robust and lightweight making it easy to install on your bike. The connection cable from the recorder box to the bullet has been engineered to be strong and ensure connections are constantly connected through vibrations and more protected by Electromatic noise. We have a wide range of brackets available to suit your requirements.
Automatic Start/Stop
When you're getting ready to race the last thing you want to be doing is fumbling around with your camera. The SmartyCam HD has been designed with this in mind and switches on/off automatically and starts/stops recording in the same way.
The SmartyCam HD can be switched on by the logger it is connected to. Switch-off is automatic too, you decide after what period of non-activity the camera will switch off.
- Display: Graphical
- Inertial platform : Internal 3 axis +5G accelerometer + 3 axis gyro +3 axis magnetometer
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
- SmartyCam GP HD 2.2
- Video format: H.264 1280 x 720 pixels @ 30 fps
- Lens: Telecretreic with 6 elements
- Field of view: 67°, 84°, 120°
- Internal battery: Rechargeable Lithium Battery 1,500mAh
- Battery charge: 700 mAh 12V
- Internal Battery Duration: 60-70 min of recording
- External power: 9-15V
- Memory Capability:
- 1.5 GB (1-hour low-quality recording)
- 2 GB (1-hour medium quality recording)
- 4 GB (1hour high-quality recording)
- Accelerometer: Three-axial + 5G
- Usage temperatures: -10°C/+60+C
- Auto power ON: Yes, if connected to an AiM Logger
- Auto power OFF: Yes
- Auto Start/Stop: Yes
- Body: Anodized Aluminium
- Dimensions: Main unit 104.6 x 79.6 x 26.6mm
- Bullet camera: 24 x 48.2mm
- Connectors: 3 binder 712 connectors + 1SMA female connector
- Bullet cable length: 2m
- Weight: Main Unit 329g - Bullet 45g
Please refer to the Technical sheets in the Downloads Tab for all other diagrams for Solo2 DL and SmartyCam GP HD 2.2.
Below is the pinout drawing for the MV Agusta plug & Play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- SmartyCam GP HD 2.2 - Bullet Cam
- External CAN cable 2m
- External power cable
- SmartyCam GP HD camera clamp mount
- MV Agusta Plug & Play connection cable
The MV Agusta plug & play kit combined with the Solo 2 DL and SmartyCam GP HD gives you the ultimate track day experience.Key Features :
This ultimate track day kit has been specifically designed for MV Agusta bikes. The kit includes a plug & play interface cable for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam GP HD to record your races and provide all the technical layovers to help improve your performance. Also added is our GP HD bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your MV Agusta ECU will give you all the engine performance information you need to help improve your driving performance.SmartyCam GP HD 2.2 Features:
The MV Agusta ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated.
SmartyCam GP HD 2.2
The AiM SmartyCam GP HD 2.2 has been engineered to provide great videos and overlay all the technical data you want to see to help improve your performance while racing. The SmartyCam GP HD is used worldwide, giving racers on circuits, open course or road racing fantastic high definition, high frame rate videos with all the data overlayed to help improve your performance. It's easy to install, robust, reliable and can withstand the extreme working conditions expected by the track or road.The SmartyCam GP HD 2.2 has a wide TFT colour display. Intelligent settings allow the camera to automatically start/stop recording by using the inbuilt 3 axis accelerometer, so you can concentrate on the track and not the camera, and immediate playback helps with setting up.
When you're getting ready to race the last thing you want to be doing is fumbling around with your camera. The SmartyCam HD has been designed with this in mind and switches on/off automatically and starts/stops recording in the same way.The SmartyCam HD can be switched on by the logger it is connected to. Switch-off is automatic too, you decide after what period of non-activity the camera will switch off.
- GPS: 10 Hz
- Memory: 4 GB
360° View
- Solo 2 DL
