{"product_id":"tyre-pressure-monitoring-system-set-of-4-sensors","title":"Système de surveillance de la pression des pneus, lot de 4 capteurs","description":"\u003cstyle\u003e\n    .LandingPage-CatTitle {\n        font-size: 24px;\n        text-align: center;\n      font-weight:600;\n    }\n    .LandingPage-CatSubTitle {\n        font-size: 22px;\n        text-align: center;\n      margin:0;\n      font-weight:600;\n    }\n    .TextBoxes {\n        font-size: 20px;\n        line-height: 32px;\n        text-align: center;\n    }\n  .features_container {\n  max-width: 1200px;\n      margin: 0 auto;\n padding-top: 20px !important;\n      padding-bottom: 20px !important;\n}\n\n.features_title {\n  font-size: 32px;\n  font-weight: 700;\n  text-align: center;\n  margin-bottom: 40px;\n  color: #333;\n  text-transform: uppercase;\n  letter-spacing: 1px;\n}\n\n.features_grid {\n  display: grid;\n  grid-template-columns: repeat(2, 1fr);\n  gap: 20px;\n  background-color: #f9f9f9;\n  padding: 30px;\n  border-radius: 8px;\n  box-shadow: 0 2px 10px rgba(0, 0, 0, 0.05);\n}\n\n.features_item {\n  font-size: 16px;\n  color: #555;\n  text-align: center;\n  padding: 15px;\n  background-color: #fff;\n  border: 1px solid #eee;\n  border-radius: 4px;\n  transition: transform 0.2s ease, box-shadow 0.2s ease;\n}\n    @media (max-width: 768px) {\n        .LandingPage-CatTitle {\n            font-size: 22px;\n        }\n        .LandingPage-CatSubTitle {\n            font-size: 20px;\n        }\n        .TextBoxes {\n            font-size: 18px;\n            line-height: 32px;\n        }\n    }\n\n\/* Mobile adjustments *\/\n@media (max-width: 600px) {\n  .features_grid {\n    grid-template-columns: 1fr; \/* Single column on mobile *\/\n    padding: 20px;\n  }\n\n  .features_title {\n    font-size: 24px;\n    margin-bottom: 30px;\n  }\n\n  .features_item {\n    font-size: 14px;\n    padding: 12px;\n  }\n}\n    \u003c\/style\u003e  \u003cdiv id=\"shopify-section-template--18373662376038__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eCapteurs de surveillance de la pression des pneus\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eCe jeu de 4 capteurs a été conçu pour être utilisé avec le \u003ctc\u003eAim\u003c\/tc\u003e Système de surveillance de la pression des pneus (TPMS). Il permet de recevoir des alertes en temps réel en cas de sous-gonflage, de réduire les risques d'accidents, d'améliorer le rendement énergétique, d'optimiser les performances des pneus et d'allonger leur durée de vie.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18373662376038__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003ePourquoi choisir le kit de 4 capteurs TPMS ?\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eLes capteurs de rechange sont idéaux si vous souhaitez ajouter un jeu de roues de secours pour des essais ou pour changer les pneus en cours de course. L'objectif principal de l'utilisation d'un capteur de pression dans chaque pneu est de surveiller des niveaux de pression spécifiques, tels que la température. Toutes les données sont envoyées au système de surveillance où elles peuvent être analysées et interprétées.\u003c\/p\u003e  \u003cp\u003eGrâce à cette technologie, chaque capteur possède son propre numéro de série (identifiant), ce qui permet au système de se distinguer des autres systèmes présents sur d'autres véhicules. Des modifications peuvent ainsi être apportées pour optimiser les performances de votre véhicule sur circuit.\u003cbr\u003e\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18373662376038__rich_text_kpNhTN\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eCaractéristiques du capteur TPMS\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eChacun des capteurs de rechange peut être programmé avec n'importe quel numéro de série attribué au récepteur. Les identifiants des capteurs de deux roues non montées peuvent être intervertis. Les capteurs sont fournis avec une valve de 11 mm.\u003c\/p\u003e  \u003cp\u003e\u003ctc\u003eAim\u003c\/tc\u003e Les écrans et les enregistreurs nécessiteront un protocole CAN, que vous pouvez télécharger dans l'onglet Téléchargements pour l'interface avec l'unité.\u003c\/p\u003e  \u003cp\u003e\u003cem is=\"\" class=\"highlighted-text inline-block not-italic relative animate\" data-style=\"text\"\u003e\u003cstrong\u003eVeuillez noter\u003c\/strong\u003e\u003c\/em\u003e:  Le système de surveillance de la pression des pneus peut être utilisé avec la plupart des véhicules. \u003ctc\u003eAim\u003c\/tc\u003e enregistreurs de tableau de bord (\u003cstrong\u003esauf Solo 2\u003c\/strong\u003e).\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18373662376038__rich_text_ENRnWW\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eAttribution automatique de l'emplacement du capteur (AASL)\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eLorsque les capteurs sont situés à un autre endroit de votre véhicule, vous pouvez les réaffecter à leur nouvel emplacement à l'aide de\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/tpms-handheld-programmer\" title=\"TPMS Handheld Programmer\"\u003eRécepteur portable TPMS\u003c\/a\u003e\u003cspan\u003e  \u003c\/span\u003e(vendu séparément).\u003c\/p\u003e  \u003cp\u003eSi les roues avant sont inversées, cette opération permet de réaffecter les données du capteur au récepteur afin que les valeurs des capteurs avant gauche soient désormais transmises sur l'identifiant CAN du capteur avant droit. Par conséquent, les données du capteur affichées sur le tableau de bord et enregistrées sont correctes et correspondent à celles du capteur avant droit.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003e  \u003cbr\u003e\u003cbr\u003e  \u003c\/h2\u003e","brand":"Aim Sensors","offers":[{"title":"Default Title","offer_id":31927997071462,"sku":"TPMS-S-4SET","price":240.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Artboard120copy3_1.5x.webp?v=1758797343","url":"https:\/\/www.aimshop.com\/fr\/products\/systeme-de-surveillance-de-pression-des-pneus-jeu-de-4-capteurs","provider":"AimShop.com","version":"1.0","type":"link"}
