AiM 10" TFT PDM Display Screen
SKU: DISPLAY-10-XC1D10000
- מחיר רגיל
- £545.00
- מחיר רגיל
- מחיר מבצע
- £545.00
- מחיר ליחידה
- לְכָל
The AiM 10" TFT PDM Display Screen is specifically designed to fit the PDM08 & PDM32 Power Distribution Modules.
Key Features:
The AiM 10" dash display is suitable for replacing all of the dashboard gauges and warning lamps. It has a fully configurable display and offers a range of layouts.
The screen can also double up as a mirror by using a separately available camera. Ideal for cars with limited rear vision. Up to two cameras can be added for both front and rear views. |
High Contrast TFT Display |
Designed for use with the AiM PDM kits User configurable display with many layout options Replaces all dashboard gauges and warning lights in one unit. |
AiM 10" TFT PDM Display Dash
- Display: 10" TFT
- Display Resolution: 1280 x 480 pixels
- Contrast: 1100:1
- Brightness: 800cd/m2
- Alarm Display Icons: Yes freely configurable
- Shift Lights: 10 configurable RGB LEDs colours
- Alarm LEDs: 6 configurable RGB LEDs colours
- Connectors: 1 Rosenberger
- Body: Anodised Aluminium
- Dimensions: 278 x 135 x 37,2mm
- Weight: 1035g
Key Features:
The AiM 10" dash display is suitable for replacing all of the dashboard gauges and warning lamps. It has a fully configurable display and offers a range of layouts. The screen can also double up as a mirror by using a separately available camera. Ideal for cars with limited rear vision. Up to two cameras can be added for both front and rear views. |
Technical Specifications
- Display: 10" TFT
- Contrast: 1100:1
- Weight: 1035g
Whats in The Box
