Aim 22-Pin Deutsch Harness for EVO5
Expand Your Data
The Aim EVO5 22-pin Deutsch harness is an optional harness to add additional sensor and output capabilities beyond the standard EVO5 setup. It features a 22-pin Deutsch female flying connector along with a 719 4-pin female connector.
Why Choose the Aim EVO5 22-Pin Deutsch Harness
The standard 37-pin harness supplied with the EVO5 covers only 4 analogue inputs: Water Temperature, Oil Temperature, Oil Pressure and Brake Pressure, so installing the 22-pin Deutsch harness opens extra functionality for advanced monitoring and control.
With the EVO5 22-pin Duetsch harness, you can add 4 more analogue sensor channels, such as steering angle, throttle position, gearbox temperature, and differential temperature, 3 extra digital speed inputs, 2 digital 12V outputs, plus RS232TX connections.
22-Pin EVO5 Deutsch Harness
