AiM EVO4 & EVO4S Download Lead
SKU: EVO4-DL
- מחיר רגיל
- £35.00
- מחיר רגיל
- מחיר מבצע
- £35.00
- מחיר ליחידה
- לְכָל
The AiM EVO4S cable is used to connect the EVO4/EVO4S data logger to a PC.
712 male binder - 3 pin | USB to PC connector |
Suitable for EVO4 - EVO4S |
The AiM EVO4S download lead is used to connect the EVO4/EVO4S data logger to a PC. It will enable data to be downloaded onto a PC and analysed with our Race Studio 3 software. Plug into the USB port on the EVO4S data logger.
With Race Studio 3 you can also analyse all data recorded by the EVO4S and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.
- 712 male binder 3 pin
- Plug into the USB port on the data logger
- EVO4S Download Lead/USB Cable
The AiM EVO4S cable is used to connect the EVO4/EVO4S data logger to a PC.Key Features :
With Race Studio 3 you can also analyse all data recorded by the EVO4S and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances. ![]() |
Technical Specifications
