{"product_id":"aim-gs-dash-motorcycle-display-with-x-log-data-logger","title":"\u003ctc\u003eAim\u003c\/tc\u003e תצוגת אופנוע GS-Dash עם לוגר נתונים XLog","description":"\u003ch3\u003eAiM GS-DASH \u0026amp; EVO4S Power Boat Dash Data Logger Kit\u003c\/h3\u003e\n\u003cp\u003eThe AiM GS-Dash \u0026amp; EVO4S Power Boat dash data logging kit. A compact and mighty kit allowing you to read data from the ECU.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e4.3\" LCD screen\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e7 configurable RGB colours\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e5 configurable RGB LED shift lights\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e4 configurable RGB alarm LEDs\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e5 pin 712 male spiral cable\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eEVO4S data logger\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_GS-DASH_EVO4S_Motocross_Dash_Data_Logger_Kit_main_description.png?v=1617182710\" style=\"width: 100%;\"\u003e\u003c\/p\u003e\n\u003ch3\u003eAiM GS-DASH \u0026amp; EVO4S Data Logger Kit\u003c\/h3\u003e\n\u003cp\u003eThe AiM GS-Dash is a compact, flexible and fully configurable graphical display showing data sampled by our AiM loggers the EVO4S.\u003c\/p\u003e\n\u003cp\u003eThis dash is small in dimension which makes it particularly suitable for small cockpit installations like powerboats. It features a 5 pin binder 712 male spiral cable which will enable you to connect your EVO4S with minimum effort.\u003c\/p\u003e\n\u003cp\u003eThe AiM EVO4S is a powerful and flexible data logger. The EVO4S samples all the information you need by the data coming from your vehicles ECU via CAN, RS232 or K-Line, accelerometers the GPS Module and additional custom sensors added to it.\u003c\/p\u003e\n\u003cp\u003eMany sensors can be added to the EVO4S. There are 5 analogue channels with configurable 12 bit 0-5V, 0-500 mV, 0-50mV inputs or thermocouple input, used to sample data coming from temperature, pressure, suspension and other sensors used for your requirements.\u003cbr\u003e2 Speed inputs, which allow monitoring the different wheel behaviour.\u003cbr\u003e1 RPM input, which manages square wave signals transmitted by the ECU, or pulse signals picked from the command.\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eDisplay\u003c\/h3\u003e\n\u003cp\u003eThe GS-Dash can be backlit in one of seven available colours, it also features an ambient light sensor that makes brightness and contrast ideal in all light conditions.\u003c\/p\u003e\n\u003cp\u003eThe GS-Dash is compact in structure and features a wide 268x128 pixel display to maximise readability.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eConfigurable Pages \u0026amp; Lap Times\u003c\/h3\u003e\n\u003cp\u003eThe GS-Dash can swap among pages showing lap times and data in a customizable way to suit your needs. You can choose the data and create pages displaying up to eight fields in each. The RPM, lap time page layout is available to display the RPM graph, lap time and three channels of your choice.\u003c\/p\u003e\n\u003cp\u003eYou can visualise the rolling time or static or predictive lap time (as an absolute value or as a difference vs. the best lap).\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eConfigurable Shift Lights \u0026amp; Alarms\u003c\/h3\u003e\n\u003cp\u003eThe GS-Dash features five RGB shift lights which can be individually configured for each gear, choosing LED colour and RPM threshold values for their activation.\u003c\/p\u003e\n\u003cp\u003eAlarm LEDs are managed in a very flexible way. You can choose the situation that generates the alarm, the LED behaviour (blinking frequency and colour) when the alarm appears and the conditions for its switch off. A warning message can also be shown.\u003c\/p\u003e\n\u003cp\u003eWhen your session is over you can easily recall your sampled data by your EVO4S data logger.\u003c\/p\u003e\n\u003cp\u003eA key summary is available at the end of each session, the best laps of the session with their times, min\/max speed and min\/max RPMs.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eKeyboard Operations\u003c\/h3\u003e\n\u003cp\u003eThe GS-Dash can perform some operations via the pop-up keyboard.\u003cbr\u003eEnabling\/disabling the backlight\u003cbr\u003eSelecting the nearest track you are racing\u003cbr\u003eChecking GS-Dash firmware version\u003cbr\u003eDeleting the data stored on EVO4S \u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_GS-Dash_Car_Racing_Dash_Display_Tech_specs_1.png?v=1617115335\" style=\"width: 100%;\"\u003e\u003c\/p\u003e\n\u003ch3\u003e\u003cbr\u003e\u003c\/h3\u003e\n\u003ch3\u003eExpand Your System\u003c\/h3\u003e\n\u003cp\u003eThese are only some of the items that can be added to our GS-Dash for incrementing the performance and the data acquired.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003cp\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Free_Download.png?v=1629297377\" style=\"width: 100%;\"\u003e\u003c\/a\u003e\u003c\/p\u003e\n\u003ch3\u003eConfigure \u0026amp; Analyse with Race Studio 3\u003c\/h3\u003e\n\u003ch4\u003eConfiguration\u003c\/h4\u003e\n\u003cp\u003eWith Race Studio 3 you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps watching the video recorded by SmartyCam HD cameras.\u003c\/p\u003e\n\u003ch4\u003eAnalysis\u003c\/h4\u003e\n\u003cp\u003eWith Race Studio 3 you can also analyse all data recorded by GS-Dash and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\" alt=\"Visit Aim Academy\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\" alt=\"Visit Aim Tech Support\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\" alt=\"Download Race Studio Software\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical\u003c\/h5\u003e\n\u003ch3\u003eAiM GS-DASH \u0026amp; EVO4s Powerboat Racing Data Logger Kit\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDisplay Resolution: \u003c\/strong\u003e268 x 128 pixels\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eBacklight:\u003c\/strong\u003e 7 configurable RGB colours\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eAmbient Light Sensor:\u003c\/strong\u003e Yes\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eShift Lights:\u003c\/strong\u003e 5 configurable RGB LEDs\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eAlarm LEDs:\u003c\/strong\u003e 4 configurable RGB LEDs\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDisplay Pages:\u003c\/strong\u003e Fully configurable\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eBody:\u003c\/strong\u003e Aluminium\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003ePushbuttons:\u003c\/strong\u003e Metallic\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDimensions:\u003c\/strong\u003e 127.8 x 82 x 22.2mm\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eWeight:\u003c\/strong\u003e 380g\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eWaterproof:\u003c\/strong\u003e IP65\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\u003cstrong\u003eEVO4S\u003c\/strong\u003e\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eECU Connection:\u003c\/strong\u003e CAN, RS232 or K-Line\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eExternal Modules:\u003c\/strong\u003e GPS Module, Channels Expansion, TC Hub, Lambda Controller, SmartyCam HD\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eAnalog Inputs:\u003c\/strong\u003e 5 fully configurable, max 1,000 Hz each\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDigital Inputs:\u003c\/strong\u003e 2-speed inputs, lap signal, coil RPM input\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eInertial Platform:\u003c\/strong\u003e Internal 3 axis ±5G accelerometer + 3 axis gyro\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDigital Outputs:\u003c\/strong\u003e 1 (1 Amp max)\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eInternal Memory:\u003c\/strong\u003e 4GB\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eConnectors:\u003c\/strong\u003e 13 Binder connectors\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eBody:\u003c\/strong\u003e Anodized Aluminium\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eLEDs:\u003c\/strong\u003e 1 system status\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDimensions:\u003c\/strong\u003e 130 x 35 x 46.6 mm\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eWeight:\u003c\/strong\u003e 330g\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eWaterproof:\u003c\/strong\u003e IP65\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_GS-Dash_Car_Racing_Dash_Display_Tech_specs_8556d1a8-172f-40af-840f-fde498c139c7.png?v=1617112827\" style=\"width: 100%;\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_GS-DASH_EVO4S_Motocross_Dash_Data_Logger_Kit_tech_specs.png?v=1617185407\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAiM GS-DASH \u0026amp; EVO4s Powerboat Racing Data Logger Kit\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eGS-Dash with spiral cable\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eEVO4S\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eGPS Module\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003ePower Cable\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eUSB Cable\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eAiM Sticker\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/docs\/gs-dash_user_guide_100_eng.pdf\" title=\"GS-Dash User Guide\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1590766826\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/docs\/aim_gs-dash_102.pdf\" title=\"GS-Dash Technical Sheet\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/aim-software\/\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/docs\/gs-dash_user_guide_100_eng.pdf\" title=\"GS Dash User Guide\" target=\"_blank\"\u003eGS Dash User Guide\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/docs\/aim_gs-dash_102.pdf\" title=\"GS Dash Technical Sheet\" target=\"_blank\"\u003eGS Dash Technical\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/aim-software\/\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/docs\/EVO4S_102_eng.pdf\" title=\"EVO4S User Guide\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1590766826\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/docs\/aim_evo4s_106.pdf\" title=\"EVO4S Technical Sheet\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003eEVO4S User Guide\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003eEVO4S Technical\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"AiM Motorcycle","offers":[{"title":"Default Title","offer_id":44223246270566,"sku":"XLOG-GS","price":941.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_gsDash_XlogMotorcycleP_PBundle_00_1.5x_bcaba3f2-0b85-405b-a1ff-1685a6b384c8.webp?v=1765968985","url":"https:\/\/www.aimshop.com\/he\/products\/aim-gs-dash-motorcycle-display-with-x-log-data-logger","provider":"AimShop.com","version":"1.0","type":"link"}
