AiM LCU-One Lambda Controller Replacement Weld on Bung Motocross
SKU: LCU-FR-MX
- מחיר רגיל
- £10.00
- מחיר רגיל
- מחיר מבצע
- £10.00
- מחיר ליחידה
- לְכָל
The AiM steel LCU-One Lambda Controller replacement weld-on bung.
Replacement weld-on bung | Steel Bung |
The AiM weld-in bungs create a permanent, easy mount for your sensor fittings.
The female-threaded steel connectors feature a natural finish.
The weld-in bungs are beneficial for retrofitting and testing applications.
Optional Extras
The Bosch LSU 4.9 Probe designed to measure the proportion of oxygen in exhaust gases. Available in the Accessories Tab.
- Weld-on Bung
- 24.7mm (1.5mm)
- x 1 Weld on Bung 24.7mm (1.5mm)
The AiM steel LCU-One Lambda Controller replacement weld-on bung.Key Features :
The AiM weld-in bungs create a permanent, easy mount for your sensor fittings.The female-threaded steel connectors feature a natural finish.
Optional Extras
The Bosch LSU 4.9 Probe designed to measure the proportion of oxygen in exhaust gases. Available in the Accessories Tab.![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_LCU-One_Lambda_Controller_Replacement_Weld_on_Bung.png?v=1625741384)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_Infrared_Tyre_Temperature_Sensor_Motocross_main_image.png?v=1625737270)
The above image shows how you can put a system together to increase your data performance. ![]() |
- Weld-on Bung
- 24.7mm (1.5mm)
![AiM LCU-One Lambda Controller Replacement Weld on Bung Motocross - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMWeldingNutforCarLambdaSensor2_9d8e384b-591d-4546-a850-53a792f39376_1445x.png?v=1613643107)
