{"product_id":"aim-mirror-reversing-camera-for-mx-series-pdm","title":"Aim Mirror \u0026 Reversing Camera for MX Series \u0026 PDM","description":"\u003ch3\u003eAiM Mirror \u0026amp; Reversing Camera for MX Series \u0026amp; PDM\u003c\/h3\u003e\n\u003cp\u003eOur AiM innovative camera will turn your dash display\/dash logger into a rear view mirror or reversing camera. Ideal for sports or race cars with limited view.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eIdeal for vehicles with limited view\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eSuitable for MX Series and PDM\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e 5 pin male binder connection\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003ePark overlay function\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch3\u003e Mirror\/Reversing Camera \u003c\/h3\u003e\n\u003cp\u003eThis camera fits the AiM MX Series dash displays and loggers and our PDM with mirror camera input port.\u003c\/p\u003e\n\u003cp\u003ePlug \u0026amp; play connection via patch lead, these are available in the options. Up to two cameras can be connected to any MX Series dash display\/ dash logger to show different perspectives. A park overlay function can be activated for an additional aid when tour reverse parking.\u003c\/p\u003e\n\u003cp\u003eThe camera is supplied with a short lead so a patch lead is usually required for installation. \u003c\/p\u003e\n\u003cp\u003eThe patch cables are available in two different options: \u003cstrong\u003eSingle patch cable\u003c\/strong\u003e for connecting 1 x AiM reversing mirror camera. \u003cstrong\u003eDouble patch cable\u003c\/strong\u003e for connecting 2 x AiM reversing mirror cameras.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003ePlease Note:\u003c\/strong\u003e Long lead length for running from the front to the back of the car - AiM patch cable are 6m in length.\u003c\/p\u003e\n\u003cp\u003eThe camera is supplied with a base mount bracket for mounting to a flat surface. Mounting through a panel is also possible and a correct sixed hole is provided to faciliatae this.\u003c\/p\u003e\n\u003ch3\u003eExpand Your System\u003c\/h3\u003e\n\u003cp\u003eThese are some of the items that can be added to your car for incrementing performance and data.\u003c\/p\u003e\n\u003ch4\u003e\u003cbr\u003e\u003c\/h4\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\" alt=\"Visit Aim Academy\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\" alt=\"Visit Aim Tech Support\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\" alt=\"Download Race Studio Software\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical\u003c\/h5\u003e\n\u003ch3\u003eAiM Mirror \u0026amp; Reversing Camera for MX Series \u0026amp; PDM\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eOptical Format: 1\/4 inch colour CMOS\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eTV System: NTSC\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eH-FOV: 170°\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003ePixel Array: 648 (H) x 488 (V)\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eFrame Rate: 60 fps\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eTemperature: -30\/80°C\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eSee the Technical Sheet in the Downloads Tab for the different patch cable drawings.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg alt=\"Aim Mirror Reversing Camera For MX Series and PDM Technical Pinout\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Mirror_Reversing_Camera_for_MX_Series_PDM_Technical_Pinout_2.png?v=1622713852\"\u003e\u003c\/p\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003cp\u003e\u003cimg alt=\"Aim Mirror Reversing Camera For MX Series and PDM Connection\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Mirror_Reversing_Camera_for_MX_Series_PDM.png?v=1622711134\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAiM Mirror \u0026amp; Reversing Camera for MX Series \u0026amp; PDM\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eOne mirror\/reversing camera - Patch cables are sold separately\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eFlush Mount kit - Drill bit \u0026amp; Flush mount\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eSwan Neck kit - Rubber pad, Screws \u0026amp; Bracket\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/aim_rear_camera_100.pdf?v=1597411088\" title=\"Aim Rear Camera Technical Sheet\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\" alt=\"Aim Rear Camera Technical Sheet\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/downloads\/software-downloads\/\" title=\"Aim Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\" alt=\"Aim Technologies Race Studio 3 Software Download\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/aim_rear_camera_100.pdf?v=1597411088\" title=\"Aim Rear Camera Technical Sheet\" target=\"_blank\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/downloads\/software-downloads\/\" title=\"Aim Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Aim Camera","offers":[{"title":"Default Title","offer_id":15880005320806,"sku":"MIR-CAM","price":125.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_mirrorCamera_00_1.5x.webp?v=1762252513","url":"https:\/\/www.aimshop.com\/he\/products\/aim-mirror-reversing-camera-for-mx-series-pdm","provider":"AimShop.com","version":"1.0","type":"link"}
