דלג לפרטי המוצר
1 שֶׁל 4
AiM MXS 1.3 Strada Sim Racing Display Logger
SKU: MXS-S-SIM
מחיר רגיל
£1,000.00
מחיר רגיל
מחיר מבצע
£1,000.00
The 5” MXS 1.3 Strada Sim Racing Display is a superb high contrast mid-size TFT display with Customisable RGB shift lights for Sim racing.
Sim Racing
 Sim Racing is one of the newest and rapidly growing frontiers of Motorsport.
Gone are the old days when gamers used to bolt the steering wheel to the kitchen table. Sim Racing is now as professional as real motorsport and that’s why e-racers and real racers are asking for more every day.
As data-driven provider, AiM is ready to step Sim Racing up to the next level, using the same advanced technology we provide, to World Class motorsport racing teams.
For the following PC Windows™ versions of:
versions
Two features are now available:
  • Analysis of your race data with the AiM proprietary software
  • Use of an AiM dashboard* during the simulation.
Analysis of Your Race Data with Race Studio 3,
"The Professional Free Software by AiM"
Racers and Gamer's want to get as closer as possible to the real Motorsport, both to perform better at the game and/or improve the simulation training for the next real race. That is the reason that pushed AiM technicians to make it possible, to use our software for analysis the data in the Sim Racing environment.
Using our free Race Studio 3 software, you can import your race or session data and analyse it with the same level of detail as a real racing car. Lap after lap, you will get to understand every single good move or mistake you did, in order to dramatically improve your performance.
RS3
Sim Screen Shot
Use of an AiM Dashboard as Data Visualisation
During the Game
As well as all those data shown on the screen while you are racing at home, by connecting via USB, you can use the true AiM dash, to display 'real time' in-game data, lap timing functions and predictive lap timing which allows you to enjoy a new sim racing experience.
AiM dashboard
How to do that?
 connect
RS3 Configure
Technology
Solutions
Button
MXS Strada Technical Specifications
Display: 5" TFT
Resolution: 800x480 pixels
Contrast: 600:1
Brightness: 700cd/m2 - 1,100 Lumen
Ambient light sensor: Yes
Alarm LEDs: 6 RGB freely configurable
Shift light: 10 integrated freely configurable RGB LEDs
CAN connections: 2
ECU connections: CAN, RS232 or K-Line
ECU compatibility: + 1,000 industry leading ECUs
Expansion CAN connection: GPS, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD
Analog inputs: 4 fully configurable, max 1,000 Hz each
Digital inputs: 1 speed input, lap signal, coil RPM input
Digital outputs: 1 (1 Amp max)
Second CAN: Yes
Body: Anodized Aluminum
Pushbuttons: Metallic
Connectors: 2 AMP connectors
Dimensions: 169.4x97x23 mm
Weight: 480 g
Power consumption: 400 mA
Waterproof: IP65
Aim MXS Strada tech spec
strada pinout
User manual ver. 1.00
The 5” MXS 1.3 Strada Sim Racing Display is a superb high contrast mid-size TFT display with Customisable RGB shift lights for Sim racing.   Sim Racing  Sim Racing is one of the newest and rapidly growing frontiers of Motorsport.
As data-driven provider, AiM is ready to step Sim Racing up to the next level, using the same advanced technology we provide, to World Class motorsport racing teams. For the following PC Windows™ versions of:
versions
Racers and Gamer's want to get as closer as possible to the real Motorsport, both to perform better at the game and/or improve the simulation training for the next real race. That is the reason that pushed AiM technicians to make it possible, to use our software for analysis the data in the Sim Racing environment. Using our free Race Studio 3 software, you can import your race or session data and analyse it with the same level of detail as a real racing car. Lap after lap, you will get to understand every single good move or mistake you did, in order to dramatically improve your performance.
RS3
Sim Screen Shot
During the Game
AiM dashboard
How to do that?
 connect
RS3 Configure
Technology
Solutions
Button
In The Box
Display: 5" TFT
Contrast: 600:1
CAN connections: 2
Second CAN: Yes
Weight: 480 g
Waterproof: IP65
strada pinout
