דלג לפרטי המוצר
1 שֶׁל 3
Aim MyChron Kart Racing Steering Wheel Black
SKU: M5-W-B
מחיר רגיל
£165.00
מחיר רגיל
מחיר מבצע
£165.00
Aim MyChron Steering Wheel
The Ideal Kart Racing Steering Wheel
The Aim MyChron Kart Steering Wheel provides an ideal solution for mounting your MyChron 5S/5S 2T and MyChron 6/6 2T Lap Timer.
Lightweight but rugged and ergonomic, it allows you to put your MyChron in the best position right in front of you.
Steering Wheel Key Features
Fits all MyChron Lap Timers
3 & 6 hole fixing
Secure leather grip
Includes MyChron mounting bracket
Design
Designed with a flat bottom and curved top, the MyChron Steering Wheel is made of an anodised aluminum frame covered by Koram Nabuk and Shammy Leather. The Nabuk coating around the sides maximises grip, bringing total control of the kart in your hands.
Measuring 340 x 320mm and supplied with a mounting bracket.
Options
Available in black with 3/6 holes, the MyChron Steering Wheel is a "must-have" tool for all MyChron owners.
Please Note: The MyChron Lap Timer is not included in the kit.
MyChron Expansion Example with SmartyCam, MyChron Expansion, Data Hub & Lambda Controller
These are just some of the expansions compatible with Aim products.
  • Diameter: 340mm
  • Weight: 600g
  • Versions: Three-hole or Six hole
  • Chassis: Anodised Aluminium
  • Finishing: Koram Nabuk and Shammy Leather
Aim MyChron Steering Wheel Dimensions
  • Aim MyChron Steering Wheel
  • MyChron Mounting Bracket
3 & 6 hole fixing
Secure leather grip
Design
Options
  • Diameter: 340mm
  • Weight: 600g
What's In The Box
