Aim Solo 2 & Solo 2 DL External 5 pin Power Lead & Light Socket Plug
SKU: SOLO2-EXP-L
- מחיר רגיל
£45.00£54.00INC VAT - UK only
- מחיר רגיל
- מחיר מבצע
- £45.00
- מחיר ליחידה
- לְכָל
AiM Solo 2 & Solo 2 DL External 5 pin Power Lead & Light Socket Plug
The AiM 5 pin power lead with a 12V lighter socket plug for the Solo2 & Solo 2 DL GPS lap timer.
5 pin - 712 male binder connection | 12V car lighter plug |
Suitable for Solo2 & Solo 2 DL GPS lap timer | |
Solo 2 & Solo 2 DL External Power Cable
The AiM external power cable to suit the AiM Solo 2 & Solo 2 DL GPS Lap Timer. Has a 5 pin Binder 712 male connector on one side and a 12V car lighter plug on the other side.
Suitable for spares, in a second vehicle, or to replace a lost or damaged lead.
- 5 pin - 712 male binder connection
- 2m Cable
- 12v car lighter plug
- Solo 2 & Solo 2 DL 5 pin power lead & 12V car lighter plug
The AiM 5 pin power lead with a 12V lighter socket plug for the Solo2 & Solo 2 DL GPS lap timer.Key Features :
The AiM external power cable to suit the AiM Solo 2 & Solo 2 DL GPS Lap Timer. Has a 5 pin Binder 712 male connector on one side and a 12V car lighter plug on the other side. Suitable for spares, in a second vehicle, or to replace a lost or damaged lead.Expand Your System
- 2m Cable
