AiM Solo, Solo 2, Solo 2 DL U Bolt Mount
SKU: SOLO-UB
- מחיר רגיל
- £67.00
- מחיר רגיל
- מחיר מבצע
- £67.00
- מחיר ליחידה
- לְכָל
The AiM U Bolt mount is suitable for a 0.5 to 1.2" bar, roll cage or railing. Used to secure for Solo GPS lap timer to your car.
Secure mounting for GPS lap timer | Ball & socket for positioning |
Suitable for Solo, Solo 2 & Solo 2 DL | 0.5 to 1.2" bar |
U Bolt Mount for GPS Lap Timer
The AiM U Bolt mount is suitable for the Solo, Solo 2 and Solo 2 DL GPS Lap Timers.
It is used to mount the Solo, Solo 2 or Solo 2 DL to a roll bar, railing or tube. The U Bolt has a unique ball and socket system that provides a solid mounting and is designed to cope with all Motorsport environments.
There are two U shaped junctions in the kit which are 2.5cm and 3cm, so the mount can be mounted to different sized bars.
- 90mm (3.54inches) arm
- Clamp base with ball 2.5cm and 3cm in diameter
- U shaped junctions
- Locknut
- Screws and washers
- 1 U Bolt Mount Bracket for Solo, Solo 2 , Solo 2 DL
The AiM U Bolt mount is suitable for a 0.5 to 1.2" bar, roll cage or railing. Used to secure for Solo GPS lap timer to your car.Key Features :
The AiM U Bolt mount is suitable for the Solo, Solo 2 and Solo 2 DL GPS Lap Timers.It is used to mount the Solo, Solo 2 or Solo 2 DL to a roll bar, railing or tube. The U Bolt has a unique ball and socket system that provides a solid mounting and is designed to cope with all Motorsport environments.
- Locknut
