AiM Spark Plug Inductive RPM Adapter
SKU: MXL-RPM-IP
- מחיר רגיל
- £75.00
- מחיר רגיל
- מחיר מבצע
- £75.00
- מחיר ליחידה
- לְכָל
+ מע"מ (בריטניה בלבד)
The AiM RPM Adapter has been designed for single cylinder 2 or 4-stroke engines.
Key Features:
The AiM spark RPM adapter has been designed for installation on single cylinder 2 or 4-stroke engines. It is a filter that converts the RPM signal sampled by induction from the spark plug into a square wave signal. The image below shows the signal sampled by induction on the left and the square wave signal on the right. |
To install the adapter connect the plastic clip to the spark plug and the cables as follows: The black cable labelled GND to the device GND pin. |
The drawing below shows the adapter correctly installed.
Key Features:
To install the adapter connect the plastic clip to the spark plug and the cables as follows: The black cable labelled GND to the device GND pin. The red cable is labelled 9-15 VDC to a +12V output (the battery positive pole for example). The blue cable labelled rpm to AiM device RPM input. |
Whats In The Box
