Aim Strada IVA Motorcycle Integration Loom MXS, MXP, MXG
SKU: MX-S-VIL-MC
- מחיר רגיל
- £195.00
- מחיר רגיל
- מחיר מבצע
- £195.00
- מחיר ליחידה
- לְכָל
The Aim pre-wired Strada 23 pins IVA Integration loom is a dedicated wiring loom to integrate with our IVA dash displays, offering a simple installation to your motorcycle's electrics.
23 pin pre-wired loom | Additional speed sensor |
Fits MX Series | Perfect for kit car builders |
The Aim Strada 23 pin IVA loom with a wheel speed sensor is a dedicated wiring loom made to integrate with the IVA dash displays. The loom will offer a simple installation for your motorcycle electrics.
The system will allow you to monitor:
All ECU information and Odometer
Oil Temperature
Engine Temperature
Fuel Levels
Side Lights
Hazards
Front Fog
Rear Fog
Parking Brake
Main Beam
Dipped Beam
LH Indicator
RH Indicator
A fuel level sender can work with the Aim Channel Expansion unit with a suitable patch lead.
The IVA loom has a pull-up resistor incorporated, which is unnecessary with the fuel level sender and can cause inconsistent readings.
- Strada IVA 23 pin Integration Loom
- Wheel Speed Sensor
- Wire Code:
- Channel 1 - Yellow - Fuel Level
- Channel 2 - Green - Engine Temperature
- Channel 3 - Violet - Oil Pressure
- Channel 4 - Orange & Brown - RH Indicator & LH Indcator
- Channel 5 - Blue - Main Beam
- Channel 6 - White - Dipped Beam
- Channel 7 - Grey - Side Lights
- Channel 8 - Pink - Rear Fog Light
- Black - RPM
- Blue-Brown-Black - Wheel Speed Sensor
- 1 X 23 pin IVA Strada Integration Loom with Wheel Speed Sensor
The Aim pre-wired Strada 23 pins IVA Integration loom is a dedicated wiring loom to integrate with our IVA dash displays, offering a simple installation to your motorcycle's electrics.Key Features :
The Aim Strada 23 pin IVA loom with a wheel speed sensor is a dedicated wiring loom made to integrate with the IVA dash displays. The loom will offer a simple installation for your motorcycle electrics.The system will allow you to monitor: All ECU information and Odometer
Oil Temperature
Engine Temperature
Fuel Levels
Side Lights
Hazards
Front Fog
Rear Fog
Parking Brake
Main Beam
Dipped Beam
LH Indicator
RH Indicator A fuel level sender can work with the Aim Channel Expansion unit with a suitable patch lead. The IVA loom has a pull-up resistor incorporated, which is unnecessary with the fuel level sender and can cause inconsistent readings.
- Wire Code:
- Black - RPM
