AiM Two-way Data Hub CAN Connection Multiplier with External Power Motorcycle
SKU: S-2PH-MC
- מחיר רגיל
- £65.00
- מחיר רגיל
- מחיר מבצע
- £65.00
- מחיר ליחידה
- לְכָל
+ מע"מ (בריטניה בלבד)
The AiM two-way Data Hub provides CAN channels and works as an interface between our AiM loggers and sensors. It also features a 12V external power connection.
Five pins 712 male Binder | Two-way hub |
Two flying cables | Build a network |
Two-Way Data Hub with External Power Connection
The compact two-way data hub with 12V flying leads provides a CAN channel and works as an interface between our Loggers and equipment such as LCU Lambda Controller, GPS Module, TC Hub, SmartyCams and many more.
The two-way Data Hub takes all the information you need to your logger with only one cable, minimizing wires overall.
The two-way data hub is beneficial when the external power allows you to connect different devices powering them through a battery.
Four-way data hub
Two-way data hub
AiM Two-way Data Hub CAN Connection Multiplier with External Power Kart
- Dimensions: 70 x 30 x 23.5mm
- CAN cable length: 40cm
- Source cable length: 165cm
- Weight: 86g
- 5 pin 712 male Binder connection
- Two flying leads 12V
- x 1 Two-way Data Hub with external power
The AiM two-way Data Hub provides CAN channels and works as an interface between our AiM loggers and sensors. It also features a 12V external power connection.Key Features :
The compact two-way data hub with 12V flying leads provides a CAN channel and works as an interface between our Loggers and equipment such as LCU Lambda Controller, GPS Module, TC Hub, SmartyCams and many more.Using many devices can result in excessive wiring. Thanks to the data hub, it can eliminate all unnecessary wiring.
Four-way data hub
Two-way data hub
These are some devices that can add extra data to your vehicle for incrementing performance and data.Technical
- Weight: 86g
