Aim Cablaggio OBDII a 14 pin per la serie MX Strada
OBDII Connection Harness for MX Stradas
The Aim 14-Pin OBDII Connection Harness provides a direct, plug & play connection for MX Strada series displays, making wiring clean and installation fast. This harness features a 14-pin AMP female connector, a 4-pin 719 female Binder, a 5-pin 712 female Binder, and a 16-pin OBDII flying connector, all pre-wired on three 1×0.5 cables.
Why Choose the Aim 14-Pin OBDII Harness
This 14-Pin OBDII Harness is designed specifically for MX Strada dash systems, and it’s ideal if you want to transfer your data to a different vehicle or if your original harness has been damaged, so you get perfect compatibility, reliable data feed and no guesswork wiring. It’s built to the same quality as other Aim components, so you can depend on it in race or track use.
14-Pin Strada OBDII Harness
