{"product_id":"aim-draw-wire-position-sensor-string-pot-750mm","title":"Draw Wire Position Sensor String Pot 750mm","description":"\u003ch3\u003eDraw Wire Position Sensor String Pot 750mm\u003c\/h3\u003e\n\u003cp\u003eThe draw-wire sensor offers a compact and highly accurate way of measuring displacement and position.\u003c\/p\u003e\n\u003ch4\u003eKey Features:\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eMeasure displacement \u0026amp; position\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eLinearity - +0.375mm\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eRobust housing\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e4 pin plastic binder connector\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003cp\u003eDraw Wire Position Sensor String Pot 750mm\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eThe draw-wire sensor offers a compact and highly accurate way of measuring displacement and position.\u003cbr\u003eThe string pots consist of a measuring cable, a spool, a spring and a rotational sensor. The line is wound tightly around the spool, and the diameter of the spool is constant. The spring is in place to maintain the tension and retraction of the cable.\u003cbr\u003e\u003cbr\u003eThe String Pot Sensor can measure linear displacements like:\u003cbr\u003eDampers compression or extension, an excellent sensor to log on to the track to check how the suspension is performing. You can set up changes such as stiffening or loosening the suspension.\u003cbr\u003e\u003cbr\u003eAlso, string rotation is measured through the rack displacement.\u003cbr\u003eMount the sensor through three screws M2.5 DIN 931 or mounting clamps. The sensor does not have to be oriented in a particular way. Prefer an installation position with a measuring wire outlet facing downwards if possible. Choose the installation position so that damage and soiling of the measuring wire are avoided.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\" alt=\"Visit Aim Academy\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\" alt=\"Visit Aim Tech Support\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\" alt=\"Download Race Studio Software\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical\u003cbr\u003e\n\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cmeta content=\"uuidGuquTSlvEdXE\" name=\"uuid\"\u003e \u003cmeta charset=\"utf-8\"\u003e\n\u003cul\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eRobust plastic housing\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eConductive plastic, wire, hybrid potentiometer\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eSmallest design in its class\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eOutput: E\/E830\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eMeasuring Range: 750mm\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eLinearity: +0.375mm\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eResolution: 6.7 pulses\/mm - 0.15mm\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eTemperature Range: -20°c. +80°c\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eMaterial: Plastic\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eWire Mounting: Eyelet\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eSensor Mounting: Mounting holes\/grooves\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eProtection Class: IP54\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eWeight: app 45g\u003c\/span\u003e\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Draw_Wire_Position_Sensor_String_Pot_750mm_tech_3.png?v=1593523390\" style=\"width: 100%;\"\u003e\u003c\/p\u003e\n\u003cp\u003eWarnings\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cmeta content=\"uuidGuquTSlvEdXE\" name=\"uuid\"\u003e \u003cmeta charset=\"utf-8\"\u003e\n\u003cul\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eDo not open the sensor housing\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eDo not let the wire snap back without control\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eAvoid banging or knocking the sensor\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eDon't let the power supply exceed its limits\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eFix the sensor with a drawn in measuring wire to the target\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eDo not damage the measuring wire\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eDo not oil or grease the measuring wire at an angle\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan data-preserver-spaces=\"true\"\u003eDo not allow to loop of the measuring wire around objects\u003c\/span\u003e\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp style=\"text-align: left;\"\u003e \u003c\/p\u003e\n\u003ch5\u003eWhats in the box\u003c\/h5\u003e\n\u003cp\u003e1 x String pot sensor with fitting screws\u003c\/p\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003ch2 class=\"container\" style=\"text-align: start;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/h2\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/stringpot-mk30-instructions.pdf?v=1711633262\" title=\"string pot User Guide\" target=\"_blank\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1590766826\" alt=\"\"\u003e\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/Race%20Studio%203-64_33206_048710_009654_20200526_163723.exe\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\" alt=\"\" style=\"display: block; margin-left: auto; margin-right: auto;\"\u003e\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cspan style=\"color: #2b00ff;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/stringpot-mk30-instructions.pdf?v=1711633262\" title=\"string pot User Guide\" target=\"_blank\"\u003e\u003cbr\u003eUser Guide\u003c\/a\u003e\u003c\/span\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cspan style=\"color: #2b00ff;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/Race%20Studio%203-64_33206_048710_009654_20200526_163723.exe\" title=\"AiM Technologies Race Studio 3 Software Download\" style=\"color: #2b00ff;\" target=\"_blank\"\u003e\u003cbr\u003eRace Studio 3\u003c\/a\u003e\u003c\/span\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/docs\/SOLO2-user-guide-100.pdf\" title=\"Aim Solo 2 User Guide\" target=\"_blank\"\u003e\u003c\/a\u003e \u003c\/p\u003e","brand":"Aim Sensors","offers":[{"title":"Default Title","offer_id":31937531576422,"sku":"SUS-POT","price":400.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_drawWirePositionStringPot_00_1.5x.webp?v=1761830895","url":"https:\/\/www.aimshop.com\/it\/products\/aim-draw-wire-position-sensor-string-pot-750mm","provider":"AimShop.com","version":"1.0","type":"link"}
