AiM Ecu Bridge With CAN/RS232 Communication Cable
SKU: SM-EB-CR
- Prezzo regolare
- £245.00
- Prezzo regolare
- Prezzo di vendita
- £245.00
- Prezzo unitario
+ IVA (solo Regno Unito)
AiM ECU Bridge With CAN/RS232 Communication Cable
The Aim Car ECU Bridge CAN RS232 Connection is available in two variants, the OBDII connector for immediate plug & play connection to the OBDII port of cars with stock ECUs or the CAN/RS232 connection for direct installation on aftermarket ecus.
They are compatible with Aim MXL Dash, Aim G-Dash and Aim Formula steering wheels, and of course with the Aim SmartyCam HD and Aim SmartyCam GP HD racing cameras.
Product code: X90BRIDGE00
ECU Bridge
ECU Bridge and RPM Bridge are two systems that are needed whenever engine data needs to be viewed on a display or a SmartyCam video (if no recording is required.
They are compatible with MXL Dash, G-Dash and Formula/GT steering wheels, and of course with the SmartyCam and SmartyCamGP.
ECU Bridge is to be used when the Engine Control Unit transmits data by either OBDII, CAN or RS232.
Aim has developed hundreds of different protocols to make compatibility with virtually all ECUs possible, either stock and market ecus. ECU Bridge has to be properly configured with Race Studio 2 software to communicate with the different visors/cameras on one side and ecus on the other side.
ECU Bridge Connection Example
RPM Bridge Connection Example
ECU with Aim Products
ECU Bridge is available in two variants:
- With OBDII connector, for immediate plug&play connection to the OBDII port of cars with stock ECUs
- With CAN/RS232 connection, for direct installation on aftermarket ecus.
RPM Bridge
RPM Bridge is to be used whenever the car has got no ECU (i.e. classic cars).
In this case, RPM data can be obtained with connection to the coil or by reading a square wave signal generated by the ignition system
- Configurable ECU interface
- CAN protocol for external modules (visors or SmartyCam HD)
- USB port for PC communication
- External power 8/18 V
- Coil signal 150-400 V
- Square wave signal 4-50 V
ECU Bridge
- ECU Bridge with connection cable (CAN/RS232 or CAN/K Line)
- USB cable
RPM Bridge
- RPM Bridge with connection cable (loose wires)
- USB cable
The Aim Car ECU Bridge CAN RS232 Connection is available in two variants, the OBDII connector for immediate plug & play connection to the OBDII port of cars with stock ECUs or the CAN/RS232 connection for direct installation on aftermarket ecus.They are compatible with Aim MXL Dash, Aim G-Dash and Aim Formula steering wheels, and of course with the Aim SmartyCam HD and Aim SmartyCam GP HD racing cameras.
ECU Bridge
ECU Bridge and RPM Bridge are two systems that are needed whenever engine data needs to be viewed on a display or a SmartyCam video (if no recording is required.They are compatible with MXL Dash, G-Dash and Formula/GT steering wheels, and of course with the SmartyCam and SmartyCamGP.
RPM Bridge
RPM Bridge is to be used whenever the car has got no ECU (i.e. classic cars).In this case, RPM data can be obtained with connection to the coil or by reading a square wave signal generated by the ignition system
Technical Specification
In The Box
ECU Bridge
- USB cable
RPM Bridge
- USB cable
ECU
