{"product_id":"aim-kart-brake-accelerator-pedal-position-sensor","title":"Kart Brake\/Accelerator Pedal Position Sensor","description":"\u003ch3\u003eAiM Kart Brake\/Accelerator Pedal Position Sensor\u003c\/h3\u003e\n\u003cp\u003eThe AiM Brake\/Accelerator pedal position sensor provides a precise indication of pedal position.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eGives a precise indication of the pedal position\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eCompatible with MyChron 4 \u0026amp; MyChron 5\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eComplete with brackets and fittings\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch3\u003eAiM Kart Brake\/Accelerator Pedal Position Sensor\u003c\/h3\u003e\n\u003cp\u003eThe AiM non-contact throttle\/brake position sensor is suitable for all AIM MyChron kart dash\/data loggers (MyChron5 S, MyChron5 and MyChron4 (both single and two temp versions). The sensor comes complete with the patch lead required to connect the sensor to the MyChron expansion box, the standard method of connecting additional sensors to your system.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eThe position sensor can be used for the throttle or the brake pedal, representing critical support for kart drivers. Providing a precise indication of timing and intensity of acceleration or braking allowing you to understand if the driver is accelerating\/braking at the right moment and with the correct strength. An essential fact to evaluate driver behaviour and improve their performance.\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eMain Functions\u003c\/h3\u003e\n\u003cp\u003eMeasures travel and show all values in percentage in a 0 to 100% range.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eAn effortless way to evaluate a drivers behaviour and improve their performance\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eProvides a precise indication of timing and intensity of braking and acceleration\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eRobust and water-resistant\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eThe sensor measures the distance between two points using a pedal position sensor. I\u003c\/p\u003e\n\u003cp\u003et gives an exact indication of the pedal position, measures its travel and shows all values in percentage in a 0 to 100% range.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Brake_Pressure_Sensor_M10_0-100_Bar_Kart_expand_your_system.png?v=1624538604\" data-mce-fragment=\"1\" data-mce-src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Brake_Pressure_Sensor_M10_0-100_Bar_Kart_expand_your_system.png?v=1624538604\"\u003e\u003cbr\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/support-home\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/software-downloads\" target=\"_blank\"\u003e \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003ch3\u003eAiM Kart Brake \u0026amp; Accelerator Pedal Position Sensor\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eThe sensor comes with a 25cm cable with a 4 pins Binder 719 male connector\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eBinder Connection Pin:\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 - Analogue signal 0-5V\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e2 - GND\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e3 - Not connected\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e4 - V reference (4.5V)\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Kart_Brake_Accelerator_Pedal_Position_Sensor_Technical_Drawing.png?v=1625756174\" alt=\"\"\u003e\u003c\/p\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAiM Kart Brake \u0026amp; Accelerator Pedal Position Sensor\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 Sensor\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 150cm patch lead\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 Bracket including one magnetic bracket\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 L bracket\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e2 washers\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 M6 x 16 Allen screw\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 nut\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cbr\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Datasheet_BrakeAccel_104_eng.pdf?v=1599644657\" title=\"AiM Brake\/Accelerator Pedal Position Sensor Technical Sheet\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Datasheet_BrakeAccel_104_eng.pdf?v=1599644657\" title=\"AiM Brake\/Accelerator Pedal Position Sensor Technical Sheet\" target=\"_blank\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimshop.com\/pages\/software-downloads\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Aim Sensors","offers":[{"title":"Default Title","offer_id":29388081299558,"sku":"S-NC","price":115.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_OTKPedalPositionSensorKit_00_1.5x.webp?v=1762440973","url":"https:\/\/www.aimshop.com\/it\/products\/aim-kart-brake-accelerator-pedal-position-sensor","provider":"AimShop.com","version":"1.0","type":"link"}
