OTK Kart Pedal Position Bracket Kit 4 Pieces
SKU: B-NC-OTK-K
- Prezzo regolare
- £70.00
- Prezzo regolare
- Prezzo di vendita
- £70.00
- Prezzo unitario
The kart pedal position bracket kit includes all four metal brackets and is specifically designed and engineered to convert existing kart pedal sensors.
Suits AiM throttle position sensor kit | Specific OTK karts |
Four-piece kit | |
This kit comes with a Brake position magnet holder, a Throttle position sensor bracket, a Throttle position magnet holder and a Brake position sensor bracket.
- Suits AiM Throttle Position Sensor Kit
- Suitable for OTK Karts
- Fout piece kit
- 1 x OTK Brake Position Sensor Bracket
- 1 x OTK Brake Position Magnet Holder
- 1 x OTK Throttle Position Sensor Bracket
- 1 x OTK Throttle Position Magnet Holder
The kart pedal position bracket kit includes all four metal brackets and is specifically designed and engineered to convert existing kart pedal sensors.Key Features :
Four-piece kit | |
- Fout piece kit
