Vai direttamente ai contenuti
Accedi
Cerca
Cerca Accedi Carrello 0
Carrello
Il tuo carrello è vuoto.
  • Continua lo shopping
    Ordina istruzioni speciali
    Subtotale
    Visualizza carrello
    Cerca
    Potentiometer Replacement Rose End Fitting - AimShop.com
    CASUS-POT-END-RJ
    In magazzino, pronto per la spedizione
    £11.00
    • Condividi su Facebook
    • Condividi su WhatsApp
    • Condivide via e-mail
    • E-mail Condivide via e-mail
    £11.00
    Replacement rose end joint fitting for the suspension potentiometer.
    Replacement rose end fitting Spare or replacement parts
    The Potentiometer rose joint fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor.
    Use as a replacement or spare part.
    One Potentiometer Rose End Fitting Replacement Supplied.
    • Replacement Potentiometer Rose End Fitting
    • 1 x Rose End Fitting Potentiometer Replacement Fitting
