{"product_id":"aim-mxm-motorcycle-data-logging-dash-display","title":"Aim MXM Motorcycle Data Logging Dash Display","description":"\u003cdiv id=\"shopify-section-template--18058585604198__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eUn cruscotto GPS compatto per moto\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eVisualizza i tuoi dati e migliora la tua esperienza di guida e di pista con funzionalità avanzate di registrazione e acquisizione dati per motociclette.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18058585604198__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003ePerché scegliere il \u003ctc\u003eAim\u003c\/tc\u003e Dash di registrazione dati MXM\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIl compatto display MXM è dotato di funzionalità avanzate di registrazione dati ed è progettato per i motociclisti che necessitano di tutte le informazioni essenziali per monitorare il comportamento della propria moto e migliorarne le prestazioni. Questo cruscotto è progettato per acquisire e visualizzare i dati dalla centralina, dal ricevitore GPS interno, dagli ingressi analogici\/digitali e dai canali matematici predefiniti.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18058585604198__rich_text_Rba3mB\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eUn'ampia gamma di fonti di dati\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIl cruscotto di registrazione dati MXM è dotato di 2 connessioni CAN per ottenere informazioni direttamente dalla centralina della moto, con un'ampia gamma di sistemi ECU compatibili tra cui scegliere. MXM offre il metodo di installazione più semplice, offrendo al contempo 4 ingressi analogici e 2 digitali per l'immissione di dati aggiuntivi.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18058585604198__rich_text_pzEm4D\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDue uscite di potenza\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIl cruscotto per moto MXM è dotato di due uscite di potenza che possono assorbire fino a 15 A ciascuna. Queste uscite possono essere configurate per attivarsi o disattivarsi in base al valore degli ingressi analogici o digitali. Questa funzionalità consente di controllare automaticamente sistemi esterni, ad esempio accendendo o spegnendo luci aggiuntive o attivando e disattivando controlli al verificarsi di eventi specifici.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18058585604198__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eLuci di cambio marcia integrate \u0026amp; Allarmi\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIl display MXM è dotato di un sistema di luci di cambio marcia integrato con 5 LED completamente configurabili, personalizzabili in base alle proprie esigenze e per ogni marcia. Altri due LED possono essere configurati per funzionare come allarmi di avvertimento, consentendo di personalizzare colori, tipi di allarme (fisso o lampeggiante), frequenza di lampeggio e messaggi di testo di accompagnamento. Le priorità di allarme possono essere impostate in base alle proprie esigenze specifiche.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18058585604198__rich_text_pXLW6j\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDisplay a cristalli liquidi nitido\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eGrazie al nitido display a cristalli liquidi (LCD), è possibile selezionare le informazioni che si desidera visualizzare e la retroilluminazione può essere commutata tra una gamma di colori disponibili, il tutto con un contrasto elevato e una grafica di facile lettura.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18058585604198__rich_text_b6t9cr\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eRichiamo dati sullo schermo\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eLe informazioni visualizzate sullo schermo possono essere completamente configurate per dare priorità alle informazioni più importanti per il pilota. Se sullo schermo sono visualizzate troppe informazioni, il pilota può scorrere più pagine utilizzando i pulsanti integrati, in modo da non perdere nulla.\u003c\/p\u003e  \u003cp\u003eAl termine della sessione, tutti i dati possono essere richiamati sullo schermo, incluso un riepilogo dei giri migliori del pilota, insieme a giri\/min massimi\/minimi, velocità e temperature. Se preferisci visualizzare i dati in modo più dettagliato, l'MXM è dotato di una funzione Wi-Fi per consentire il trasferimento rapido e sicuro dei dati a un laptop o PC fino a 50 metri di distanza, così non dovrai più portare il laptop alla moto.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18058585604198__rich_text_UzrjLG\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEspandi il tuo sistema\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eAmplia le capacità del tuo MX Logger con una gamma di accessori compatibili per garantire precisione e affidabilità.\u003cbr\u003e\u003cbr\u003eLCU-One S ti permette di ottimizzare la carburazione del tuo motore per mantenerla al meglio e migliorarne le prestazioni. Oltre al convertitore CAN analogico, puoi scegliere, in base alle tue esigenze, tra 5 diversi cablaggi sdoppiati. Sono disponibili fino a 4 termocoppie o 4 canali analogici 0-5V\/0-12V.\u003cbr\u003e\u003cbr\u003eLa serie SmartyCam 3 si collega anche per registrare video sincronizzati e dati di telemetria pronti per l'analisi in Race Studio 3.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003ch3\u003e  \u003cbr\u003e\u003cbr\u003e  \u003c\/h3\u003e","brand":"AiM Motorcycle","offers":[{"title":"Default Title","offer_id":12637111484518,"sku":"MXM","price":1045.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_MXM_00copy5_1.5x_ca77d49c-745f-4bb3-a82a-069e09dc4d95.webp?v=1757588346","url":"https:\/\/www.aimshop.com\/it\/products\/aim-mxm-motorcycle-data-logging-dash-display","provider":"AimShop.com","version":"1.0","type":"link"}
