{"product_id":"aim-mxs-strada-5-tft-car-dash-display-with-road-icons","title":"Aim MXS 1.3 Strada 5\" TFT Car Dash Display with Road Icons","description":"\u003cstyle\u003e\n    .LandingPage-CatTitle {\n        font-size: 24px;\n        text-align: center;\n      font-weight:600;\n    }\n    .LandingPage-CatSubTitle {\n        font-size: 22px;\n        text-align: center;\n      margin:0;\n      font-weight:600;\n    }\n    .TextBoxes {\n        font-size: 20px;\n        line-height: 32px;\n        text-align: center;\n    }\n  .features_container {\n  max-width: 1200px;\n      margin: 0 auto;\n padding-top: 20px !important;\n      padding-bottom: 20px !important;\n}\n\n.features_title {\n  font-size: 32px;\n  font-weight: 700;\n  text-align: center;\n  margin-bottom: 40px;\n  color: #333;\n  text-transform: uppercase;\n  letter-spacing: 1px;\n}\n\n.features_grid {\n  display: grid;\n  grid-template-columns: repeat(2, 1fr);\n  gap: 20px;\n  background-color: #f9f9f9;\n  padding: 30px;\n  border-radius: 8px;\n  box-shadow: 0 2px 10px rgba(0, 0, 0, 0.05);\n}\n\n.features_item {\n  font-size: 16px;\n  color: #555;\n  text-align: center;\n  padding: 15px;\n  background-color: #fff;\n  border: 1px solid #eee;\n  border-radius: 4px;\n  transition: transform 0.2s ease, box-shadow 0.2s ease;\n}\n    @media (max-width: 768px) {\n        .LandingPage-CatTitle {\n            font-size: 22px;\n        }\n        .LandingPage-CatSubTitle {\n            font-size: 20px;\n        }\n        .TextBoxes {\n            font-size: 18px;\n            line-height: 32px;\n        }\n    }\n\n\/* Mobile adjustments *\/\n@media (max-width: 600px) {\n  .features_grid {\n    grid-template-columns: 1fr; \/* Single column on mobile *\/\n    padding: 20px;\n  }\n\n  .features_title {\n    font-size: 24px;\n    margin-bottom: 30px;\n  }\n\n  .features_item {\n    font-size: 14px;\n    padding: 12px;\n  }\n}\n    \u003c\/style\u003e\n\u003ch2 class=\"LandingPage-CatTitle\"\u003eAim MXS 1.3 Strada 5\" TFT Dash Display with Road Icons\u003c\/h2\u003e\n\u003cp class=\"TextBoxes\"\u003eThe MXS Strada with Road Icons is one of the most widely used dash displays on roads around the world.\u003c\/p\u003e\n\u003cdiv class=\"features_container\"\u003e\n\u003ch2 class=\"LandingPage-CatTitle\"\u003eMXS 1.3 Strada Key Features\u003c\/h2\u003e\n\u003cdiv class=\"features_grid\"\u003e\n\u003cdiv class=\"features_item\"\u003eCompact 5\" Display\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eRange Of Data Sources\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eIntegrated Shift Light Array\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003e1,000+ Industry-Leading ECUs\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eHigh-Contrast TFT Display\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eGPS09 Module (Optional)\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003e6 Configurable RGB LEDs\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eFreely Configurable Pages\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eFlexible Alarms\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003e8 Analogue Inputs\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eCAN Output\u003c\/div\u003e\n\u003cdiv class=\"features_item\"\u003eConfigure Data\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003chr\u003e\n\u003cdiv\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_MXS_1.2_Strada_5_TFT_Dash_Display_with_Road_Icons_Main_Description.png?v=1615382349\"\u003e\u003c\/div\u003e\n\u003ch2 style=\"margin-top: 0;\" class=\"LandingPage-CatTitle\"\u003eWhy Choose The MXS 1.3 Strada Car Dash Display With Road Icons\u003c\/h2\u003e\n\u003cp class=\"TextBoxes\"\u003eThe MXS 1.3 Strada is one of our most widely used dashes on tracks and roads all over the world. The MXS 1.3 Strada has a 5\" colour TFT display that offers a great visual impact. You can configure the dash to show all the information coming from the ECU, analogue \/digital inputs, predefined math channels and an optional GPS Module.\u003c\/p\u003e\n\u003cp class=\"TextBoxes\"\u003eThe MXS 1.3 Strada is available with a choice of connection. Choose either the OBDII or K-Line CAN, depending on whether you want to connect to the car's ECU or OBDII port or directly to the ECU through the CAN channel.\u003c\/p\u003e\n\u003chr\u003e\n\u003ch3 class=\"LandingPage-CatSubTitle\"\u003eEasy Connection\u003c\/h3\u003e\n\u003cp class=\"TextBoxes\"\u003eConnecting the MXS 1.3 Strada dash to your ECU is simple. You can sample and display dozens of channels straight from the car's ECU. This is usually the quickest and easiest setup, needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors. The sampled data depends on the actual ECU, but will typically include RPM, throttle position, (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air\/fuel ratio). The list of available ECU drivers is 1000+ and is constantly being updated and upgraded.\u003c\/p\u003e\n\u003chr\u003e\n\u003ch3 class=\"LandingPage-CatSubTitle\"\u003eDigital Outputs\u003c\/h3\u003e\n\u003cp class=\"TextBoxes\"\u003eThe MXS 1.3 Strada features 1 AMP digital output configurable to be activated\/deactivated depending on the value of the analogue \/digital inputs or on the impulses coming from the ECU. This allows you to automatically run external systems, such as switching on\/off additional lights, to activate\/deactivate a cooling fan or circulation pumps when a certain event happens.\u003c\/p\u003e\n\u003cp class=\"TextBoxes\"\u003eWith CAN output, you can send messages directly to an existing  CAN network to improve the range of vehicle control possibilities.\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3 class=\"LandingPage-CatSubTitle\"\u003eDisplay\u003c\/h3\u003e\n\u003cp class=\"TextBoxes\"\u003eThe MXS 1.3 Strada has a 5\" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3 class=\"LandingPage-CatSubTitle\"\u003ePre-Configured Pages\u003c\/h3\u003e\n\u003cp class=\"TextBoxes\"\u003eThe MXS 1.3 Strada shows the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can customise pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy; just use the pushbuttons.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3 class=\"LandingPage-CatSubTitle\"\u003eFlexible Shift Light \u0026amp; Alarms\u003c\/h3\u003e\n\u003cp class=\"TextBoxes\"\u003eThe ten multi-coloured RGB shift lights can be customised to your liking, defining the RPM threshold on analogue or digital inputs, ECU values, expansion values, math channels or optional GPS option. You can choose the conditions and colours, select a solid arm or flashing one and the flashing frequency. You can also configure an accompanying text message and set the alarm priorities.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3 class=\"LandingPage-CatSubTitle\"\u003eCamera Inputs\u003c\/h3\u003e\n\u003cp class=\"TextBoxes\"\u003eTwo analogue camera inputs are available to switch your display into a mirror camera, through a pushbutton command or event management. The camera is sold separately.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003cdiv\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_MXS_1.2_Strada_5_TFT_Dash_Display_with_Race_Icons_harness.png?v=1615376452\"\u003e\u003c\/div\u003e\n\u003ch3 class=\"LandingPage-CatSubTitle\"\u003ePin Harness\u003c\/h3\u003e\n\u003cp class=\"TextBoxes\"\u003eThe MXS 1.3 Strada has a choice of ECU connection. Choose between the OBDII or K-Line CAN. Depending on whether you want to connect to the car's ECU using the OBDII port or directly to the ECU through the CAN channel.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003cdiv\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_MXS_1.2_Strada_5_TFT_Dash_Display_with_Road_Icons_Expand_your_system.png?v=1615382173\"\u003e\u003c\/div\u003e\n\u003ch3 class=\"LandingPage-CatSubTitle\"\u003eExpand Your System\u003c\/h3\u003e\n\u003cp class=\"TextBoxes\"\u003eThese are only some of the items that can be added to our MXS 1.3 Strada for incrementing the performance and the data acquired.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003cdiv\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Free_Download.png?v=1629297377\"\u003e\u003c\/div\u003e\n\u003ch2 class=\"LandingPage-CatTitle\"\u003eConfigure \u0026amp; Analyse with Race Studio 3\u003c\/h2\u003e\n\u003ch3 class=\"LandingPage-CatSubTitle\"\u003eConfiguration\u003c\/h3\u003e\n\u003cp class=\"TextBoxes\"\u003eWith Race Studio 3, you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps by watching the video recorded by SmartyCam HD cameras.\u003c\/p\u003e\n\u003ch3 class=\"LandingPage-CatSubTitle\"\u003eAnalysis\u003c\/h3\u003e\n\u003cp class=\"TextBoxes\"\u003eWith Race Studio 3, you can also analyse all data recorded by MXS Strada and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003ch3\u003eAim MXS 1.3 Strada 5\" TFT Dash Display with Road Icons\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDisplay : \u003c\/strong\u003e5\" TFT\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eResolution:\u003c\/strong\u003e 800 x 480 pixels\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eContrast:\u003c\/strong\u003e 600:1\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eBrightness:\u003c\/strong\u003e 700cd\/m2 - 1,100 Lumen\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eAmbient Light Sensor:\u003c\/strong\u003e Yes\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eAlarm LEDs:\u003c\/strong\u003e 6 RGB freely configurable\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eShift Lights:\u003c\/strong\u003e 10 integrated freely configurable RGB LEDs\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eCAN Connections: \u003c\/strong\u003e2\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eECU Connections:\u003c\/strong\u003e CAN, RS232 or K-Line\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cb\u003eECU Compatibility:\u003c\/b\u003e +1000 industry-leading ECUs\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eExpansion CAN Connection:\u003c\/strong\u003e GPS, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eAnalogue Inputs:\u003c\/strong\u003e 8 fully configurable, max 1000 Hz each\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDigital Inputs:\u003c\/strong\u003e 1-speed input, coil RPM input\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDigital Outputs:\u003c\/strong\u003e 1 (1 A max)\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eSecond CAN:\u003c\/strong\u003e Yes\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eBody:\u003c\/strong\u003e Anodized Aluminium\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003ePushbuttons:\u003c\/strong\u003e Metallic\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eConnectors:\u003c\/strong\u003e 2 AMP connectors + 1 Binder connector\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003ePower Consumption:\u003c\/strong\u003e 400 mA\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eDimensions:\u003c\/strong\u003e 169.4 x 4 x 97 x 23mm\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eWeight: \u003c\/strong\u003e480g\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eWaterproof: \u003c\/strong\u003eIP65\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_MXS_1.2_Strada_5_TFT_Dash_Display_with_Race_Icons_Tech_Specs.png?v=1615369058\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's In The Box\u003c\/h5\u003e\n\u003ch3\u003eAim MXS 1.3 Strada TFT Car Dash Display with Road Icons\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eMXS Strada 1.2\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eUSB Cable\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e14 Pin Standard Wiring\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eAim Sticker\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/mxs-strada\/MX1.2+1.3_Strada_user_guide.pdf\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1590766826\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/mxs-strada\/aim_mxs_1.3_strada.pdf\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimshop.com\/pages\/software-downloads\" title=\"AiM Technologies Race Studio 3 Software Download\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/mxs-strada\/MX1.2+1.3_Strada_user_guide.pdf\" target=\"_blank\"\u003eUser Guide\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/support.aimshop.com\/downloads\/product-documents\/mxs-strada\/aim_mxs_1.3_strada.pdf\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimshop.com\/pages\/software-downloads\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"AiM Car","offers":[{"title":"Default Title","offer_id":39443898794086,"sku":"MXS-S-I-OBDII","price":1030.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_mxs_strada_road_00_a038de2f-9029-43dd-9da1-1fed72649c24.webp?v=1770907493","url":"https:\/\/www.aimshop.com\/it\/products\/aim-mxs-strada-5-tft-cruscotto-per-auto-con-icone-stradali","provider":"AimShop.com","version":"1.0","type":"link"}
