1 di 4
AiM MXS Strada Aprilia IVA 5" TFT Display Plug & Play Kit
SKU: MXS-S-APR-KIT
Prezzo regolare
£1,075.00
Prezzo regolare
Prezzo di vendita
£1,075.00
AiM MXS 1.3 Strada IVA Compliant 5" Dash Display Plug & Play Kit
The MXS 1.3 Strada IVA compliant digital dash display is a complete road legal display solution for OEM kit car and race builders.
5" compact TFT display 6 alarm RGB LEDs
CAN output Configure data
The MXS 1.3 Strada is one of our most widely used dashes on tracks and roads all over the world. The MXS 1.3 Strada has a 5" colour TFT display that offers a great visual impact. You can configure the dash to show all the information coming from the ECU, analogue /digital inputs, predefined math channels and an optional GPS Module.
Connecting the MXS 1.3 Strada dash to your ECU is simple. You can sample and display dozens of channels straight from the vehicle ECU. This is usually the quickest and easiest setup, needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors.
The 23 pin loom has pre-configured connections for all the main relevant electrical items in your vehicle such as oil, temperature, fuel level, sidelights, hazards, front and rear fog, handbrake, main beam, dipped beam and left and right-hand indicator. A speed sensor is also included in the kit to connect to this additional loom.
Digital Outputs
The MXS 1.3 Strada features 1 AMP digital output configurable to be activated/deactivated depending on the value of the analogue /digital inputs or on the impulses coming from the ECU. This allows you to automatically run external systems, such as switching on/off additional lights, to activate/deactivate a cooling fan or circulation pumps when a certain event happens.
With CAN Output you can send messages directly to an existing  CAN network to improve the range of vehicle control possibilities.
The MXS 1.3 Strada has a 5" TFT high contrast colour display. The visual quality is optimized by the ambient light sensor which keeps the backlight at the best brightness levels.
Pre-configured Pages
The MXS 1.3 Strada shows the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can custom pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy just use the pushbuttons.
Flexible Shift Light & Alarms
Camera Inputs
These are only some of the items that can be added to our MXS 1.3 Strada for incrementing the performance and the data acquired.
With Race Studio 3 you can also analyse all data recorded by MXS 1.3 Strada and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
  • Display : 5" TFT
  • CAN Connections: 2
  • Second CAN: Yes
  • Body: Anodized Aluminium
  • Pushbuttons: Metallic
  • Power Consumption: 400 mA
  • Dimensions: 169.4 x 4 x 97 x 23mm
  • Weight: 480g
  • Waterproof: IP65
  • MXS 1.3 Strada
  • 23 pin IVA Loom
  • Wheel Speed Sensor
Connecting the MXS 1.3 Strada dash to your ECU is simple. You can sample and display dozens of channels straight from the vehicle ECU. This is usually the quickest and easiest setup, needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors. The 23 pin loom has pre-configured connections for all the main relevant electrical items in your vehicle such as oil, temperature, fuel level, sidelights, hazards, front and rear fog, handbrake, main beam, dipped beam and left and right-hand indicator. A speed sensor is also included in the kit to connect to this additional loom.
Digital Outputs
The MXS 1.3 Strada features 1 AMP digital output configurable to be activated/deactivated depending on the value of the analogue /digital inputs or on the impulses coming from the ECU. This allows you to automatically run external systems, such as switching on/off additional lights, to activate/deactivate a cooling fan or circulation pumps when a certain event happens. With CAN Output you can send messages directly to an existing  CAN network to improve the range of vehicle control possibilities.
Camera Inputs
  • Display : 5" TFT
  • Second CAN: Yes
  • Weight: 480g
  • Waterproof: IP65
  • MXS 1.3 Strada
  • 23 pin IVA Loom
