1 di 4
AiM PDM08 Data Logging Power Distribution Module Only
SKU: PDM-8-XC1PDM0802G050
Prezzo regolare
£1,010.00
Prezzo regolare
Prezzo di vendita
£1,010.00
Available for Pre-Order - Delivery January 2021
AiM PDM08 Power Distribution Module.
The AiM PDM08 has been designed to distribute power to multiple circuits on your vehicle.
Key Features:
  • 8 RGB LEDs
  • CAN connections - 3
Power Distribution Module 08
The AiM PDM08 is an 8-channel advanced power distribution module designed to power a multitude of vehicle circuits removing the need for the traditional fuse boxes and relays. It allows for a simplified wiring harness with increased reliability and control functions.
The PDM08 is available on its own like this one or with a choice of 6"" or 10"" dash displays. The PDM08 is also capable of receiving data from the vehicle's ECU and even includes a data logger and GPS module for lap liming and track mapping. (See listing for PDM08 with GPS).
Simplifies electronic installations with greater control.
8 outputs, ideal for controlling vehicle electrical circuits.
Built-in data logging facility to log all PDM outputs and ECU data plus lap timing.
Dash controller with 6"" or 10"" dash display options.
GPS Module options for lap timing and track mapping.
Rugged aluminium case designed to stand harsh Motorsport environments.
PDM Power Outputs
The AiM PDM08 features 8 x 15A current outputs with a total continuous max current of 120A.
Each of the outputs provides feedback to the data logger to provide vital information such as open circuits, short circuits, high/low voltage, the number of fault retires and the time between the reties is user definable. All outputs can be configured as PWM's for a soft start/stop. All the PDM circuits can be set up and monitored within our Race Studio 3 Software.
PDM08 Inputs
The PDM08 features 6 x analogue / digital inputs and 2 x speed inputs.
PDM08 Data
Management
The PDM08 is capable of receiving and recording data from the following sources:
ECU - Over 1000 protocols available / Digital / Analogue Inputs / Internal 9 axis EMU / GPS - Lap time and position / Expansions / Push Buttons - From RIO02 module or any commercial CAN keypad / PDM outputs - Currents and status of each channel individually / Other user defined math channels.
GPS Option ( Not Included)
The GPS Module option provides easy lap timing and lap position for track mapping. The PDM has over 4000 tracks in the database so once you arrive at the track the system already knows the timing points so you can just get on with your driving. The GPS Module is available with various lead lengths to suit differing applications.
Dash Display Option ( Not Included)
Suitable for replacing all of the dashboard gauges and wiring lamps, these TFT dash displays are available in 6"" or 10"" versions. Both versions have fully configurable displays and offer a range of layouts. These displays can also double up as a reversing mirror by using our separate camera, which is sold separately. Ideal for cars with limited rear vision. Up to two cameras can be added for both front and rear views. The mirror camera connects to the PDM through the 5-pin binder connector.
PDM08 Connection Example
Compare AiM Dashes
AiM Product Video
  • Input - 6 fully configurable, max 500 Hz each
  • Power Outputs - 8 rated up to 20 A (mid power) Protected for: over voltage, under voltage, over current, over temperature
  • Lin Bus - 1
  • CAN Connections - 3
  • Intertial Platform - 3 axis + 5G accelerometer + 3 axis gyro + axis magnetometer
  • Internal Memory - 4 GB
  • External Modules - GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD, Formula Steering Wheel, Remote I/O Pushbutton Module.
  • External Analogue Camera Input - NO
  • Body - Anodised Aluminium
  • Waterproof - IP65
  • Dimensions - 161 x 1000.6 x 50.6mm
Search compatible ECUs by manufacturer supported by AiM
      Key Features:
      • 8 RGB LEDs
      PDM Power Outputs
      PDM08 Inputs
      PDM08 Data
      Management
      Compare AiM Dashes
      AiM Product Video
      Technical Specifications
      • Lin Bus - 1
      • Waterproof - IP65
      ECU Connections & Support
      Whats in The Box
