1 di 2
AiM SmartyCam GP HD Recording Box Suction Cup Mount 2.1 & 2.2 for Motorcycle
SKU: SM-WM-GP-R
Prezzo regolare
£80.00
Prezzo regolare
Prezzo di vendita
£80.00
AiM SmartyCam GP HD Suction Cup Mount For Recording Box 2.1 & 2.2
The SmartyCam GP HD can be installed using the GP HD suction cup mount. It is suitable for SmartyCam GP HD 2.1 and 2.2 SmartyCams.
Secure mounting for SmartyCam Ball & socket system
Complete with fitting kit For GP HD 2.1 & 2.2
The AiM SmartyCam GP HD suction cup mount for the recording box is for mounting the SmartyCam's recording box to a windscreen or flat surface.
The suction cup mount has a unique ball and socket system which offers optimum positioning and has been designed to cope with the rigours of motorsport.
The mount will keep the recording box safe and secure and can be placed in a position clear from the driver so it doesn't get in the way.
Suction Cup Mount
Securely attaches to any windscreen or flat surface.
Includes all fixtures and fittings.
  • For use with SmartyCam 2.1 & 2.2 GP HD
  • Arm height 90mm ( 3.54 inches)
  • Suction cup
  • 90mm arm
  • Clamp base with ball
  • Mounting bracket
  • Locknuts
  • Washers and screws
Technical sheet Race Studio 3
The AiM SmartyCam GP HD suction cup mount for the recording box is for mounting the SmartyCam's recording box to a windscreen or flat surface. The suction cup mount has a unique ball and socket system which offers optimum positioning and has been designed to cope with the rigours of motorsport. The mount will keep the recording box safe and secure and can be placed in a position clear from the driver so it doesn't get in the way.
Suction Cup Mount
  • Suction cup
  • 90mm arm
  • Mounting bracket
  • Locknuts
