AiM SmartyCam GP HD 2.2 & 3 ECU CAN & 3.5mm Female Jack Plug for External Microphone & External Power Harness
SKU: SM-ECU-EM
- Prezzo regolare
- £80.00
- Prezzo regolare
- Prezzo di vendita
- £80.00
- Prezzo unitario
Aim SmartyCam 2.2 ECU CAN Harness
External power lead to allow battery connection 12v.
Key Features:
AiM SmartyCam 2.2 ECU CAN Harness
The AiM SmartyCam GP HD 2.2 ECU CAN, power and integrated 3.5mm female jack plug cable has Motorsport engineered grade cable and fittings so it is able to with stand the harshness of Motorsport. The power cable is a useful accessory for when you want the reassurance of having the camera powered from your vehicles 12v system. |
Provides direct battery power supply to an AiM SmartyCam 2.2 camera Featuring a CAN high and CAN low connection inputs for the ECU Please Note: This connection cable is not required if you are connecting the SmartyCam to a logger or dash as the power will be supplied to the camera through the CAN connection. |
AiM Technologies are committed to supplying professional engineers quality products. Our cables and accessories are well engineered and designed for rigours Motorsport. Our racing components are amongst the best in the industry today. |
Unlock your potential |
Key Features:
The female 3.5mm jack allows you connect to an on-board radio to intercom system (additional cable may be required depending on your radio / intercom). Provides direct battery power supply to an AiM SmartyCam 2.2 camera Featuring a CAN high and CAN low connection inputs for the ECU Please Note: This connection cable is not required if you are connecting the SmartyCam to a logger or dash as the power will be supplied to the camera through the CAN connection. |
