1 di 2
AiM Solo 2 & Solo 2 DL External 5 pin Power Lead & Light Socket Plug
SKU: SOLO2-EXP-L
Prezzo regolare
£45.00
Prezzo regolare
Prezzo di vendita
£45.00
The AiM 5 pin power lead with a 12V lighter socket plug for the Solo2 & Solo 2 DL GPS lap timer.
5 pin - 712 male binder connection 12V car lighter plug
Suitable for Solo2 & Solo 2 DL GPS lap timer
Solo 2 & Solo 2 DL External Power Cable
The AiM external power cable to suit the AiM Solo 2 & Solo 2 DL GPS Lap Timer. Has a 5 pin Binder 712 male connector on one side and a 12V car lighter plug on the other side.
Suitable for spares, in a second vehicle, or to replace a lost or damaged lead.
  • 5 pin - 712 male binder connection
  • 2m Cable
  • 12v car lighter plug
  • Solo 2 & Solo 2 DL 5 pin power lead & 12V car lighter plug
The AiM external power cable to suit the AiM Solo 2 & Solo 2 DL GPS Lap Timer. Has a 5 pin Binder 712 male connector on one side and a 12V car lighter plug on the other side. Suitable for spares, in a second vehicle, or to replace a lost or damaged lead.
  • 2m Cable
