AiM Strada 1.1 23 Pin Analogue Harness MXS, MXG, MXP
SKU: MXS-S-L-AN
- Prezzo regolare
- £145.00
- Prezzo regolare
- Prezzo di vendita
- £145.00
- Prezzo unitario
+ IVA (solo Regno Unito)
AiM 1.1 Strada MX Series 23 Pin Harness
AiM MXG, MXP, MXS 23 pin connector with a harness for 1.1 for older model dashes.
Key Features:
Optional 23 Pin Harness
This optional 23 Pin AMP connector harness/ loom makes installation easier by including pre-wired connections. With the 4 analogue, speed and lap channels all being terminated with 719 binder plugs. These can be extended using the 719 - 719 patch lead if required. This 23-pin harness has been designed for older models go the MXS, MXP, and MXG. Please Note: 1.1 version is for older model dashes only |
Unlock your potential |
AiM Strada 1.2 23 Pin Analogue Harness for the MXG, MXP, MXS 1.1
- Analogue channels 1-4
- Speed
- Lap
- RS232tx/RX
- Digital output
- CAN2+/-
AiM Strada 1.2 23 Pin Analogue Harness 1.1
Key Features:
Optional 23 Pin HarnessThis optional 23 Pin AMP connector harness/ loom makes installation easier by including pre-wired connections. With the 4 analogue, speed and lap channels all being terminated with 719 binder plugs. These can be extended using the 719 - 719 patch lead if required. This 23-pin harness has been designed for older models go the MXS, MXP, and MXG. Please Note: 1.1 version is for older model dashes only |
- Speed
- Lap
- RS232tx/RX
- Digital output
- CAN2+/-
Whats In The Box
