Aim Taipan Motocross Engine Control Unit
Motocross bike manufactures that Taipan ECU is compatible with: KTM, GASGAS, Husqvarna, Kawasaki, Honda & Ducati
The Taipan Engine Control Unit (ECU) is our aftermarket plug & play ECU exclusively designed for off-road motocross bikes: GASGAS, KTM, Honda, Kawasaki, Ducati and Husqvarna. Thanks to its high-technology 32-bit core, it represents an important step forward to improve the performance of your motorcycle, without sacrificing reliability and smoothness.
Why Choose the Taipan ECU
Engine control requires precision. With its high technology 32-bit core, at 20,000 RPM, the Taipan ECU guarantees precision of 1/10 of a degree: this means an accuracy within 0.8 microseconds (µs) for turning the spark ON.
This precision is the key to guarantee:
  • A very consistent engine rotation.
  • The possibility of repeating dozens of tests at the bench, always obtaining the same result.
  • A perfect reactivity at every minimum change of any point of a map, resulting in more power at the wheel.
Handlebar Switch 2
You can choose from up to five selectable maps with the Handlebar Switch 2.
The Taipan can manage up to five maps that can be selected both by OEM switches (Honda, Husqvarna, KTM) or even more easily by the Aim Handlebar Switch 2.
HBS2 is the compact, high-performance, and built tough Handlebar Switch.
If you're looking for a highly flexible and ergonomic switch, the model from Aim offers a great solution with 4 push buttons and 11 integrated LEDs.
  • Map Management
  • Fuel Trim
  • Traction Control Management
  • Launch Control Management
  • Buttons Setting Memorisation
HBS2 also allows the management of quick shifting on factory-equipped bikes.
Integrate FREE Spark Software
SPARK is the intuitive software that lets you control, customise, and fine-tune your bike’s performance.
From map management to traction control, SPARK puts advanced tuning at your fingertips.
Thanks to the UC Bridge, designed to integrate Aim ECUs with the software, users can efficiently manage configurations, settings, and engine maps.
Carica il video: Spark Software interface
UC Bridge License Types
UC Bridge is available in two distinct license types:
User License
This license provides end users with essential functionalities, including:
  • Receiving engine maps from your tuner and flashing them directly to the ECU
  • Displaying system exceptions or logged issues from the ECU within the SPARK software
  • Adjusting fuel injection corrections across various RPM ranges
Tuner License
Tailored for professional tuners, this license enables full control over map creation and configuration, including:
  • Designing and modifying base maps
  • Create custom maps from scratch
  • Managing configurations to be sent and applied to the ECU
Smoothing algorithm feature on Spark Software
Smoothing Algorithm
By selecting at least three contiguous cells and right-clicking, a context menu appears. Choosing ‘Smoothing’ from the menu applies the smoothing algorithm, which is also reflected in the 2D view.
3D visualisation on Spark Software
3D Visualisation
3D visualisation mode complements the 2D view. The 3D graph supports rotation, zooming, and panning, with controls detailed in the tab’s legend.
Tyre pressure sensor calibration gauge on Spark Software
TPS Sensor Calibration Gauge
TPS Sensor Calibration Gauge provide a clearer and more intuitive visualisation of the TPS signal voltage.
Carica il video: Showcase of the Spark Software on mobile devices
Download the FREE Spark App on iOS or Android
SPARK is now available as a mobile app for both Android and iOS, with seamless Bluetooth connectivity to your bike.
Connect your smartphone to the Taipan and Yarara ECU in two ways:
  • Via the CAN-BT Module, for instant access to key engine data and real-time telemetry.
  • Using the XLog, if you want to collect data while driving as well.
CAN-BT Module
The CAN-BT Module grants instant access to key engine data from your Taipan ECU.
Installing the SPARK App on your smartphone provides a streamlined, data-driven interface for real-time monitoring of live engine parameters.
Get real-time insights into:
• Live Dash Telemetry
• Warning and Alerts for Diagnostic Faults
• Map Switching
• Fuel Adjustments
Shop now
Aim CAN-BT Module
  • Two 0-5V analogue inputs sampled at 1,000Hz each - could be alternatively used as a switch to ground
  • One low-side driver (1A)
  • Two CAN bus - one for calibration purposes, one for expansions (Aim Handlebar Switches, data loggers, dashes etc)
  • Three JST JWPF waterproof auxiliary connectors
  • Power Consumption: 150mA
  • Body: PA6 + 30% glass fiber
Connectors
  • 1 JST 04T-JWPF-VSLE-S connector
  • 1 JST 08R-JWPF-VSLE-D connector
  • 1 JST 04R-JWPF-VSLE-S connector
  • 1 33-pin male connector
  • Weight: 260g
  • IP67
SKU: C-ECU
Videos
Carica il video: Plug & play installation of the Cobra ECU (now Taipan)
Taipan User Guide
Tuner User Guide
Taipan Tech Sheet
Spark Tuning Software
