{"product_id":"bmw-s1000rr-s1000rr-hp4-aim-evo4s-logger-plug-play-cable","title":"BMW S1000RR \u0026 S1000RR HP4 Aim EVO4S Logger Plug \u0026 Play Cable","description":"\u003ch3\u003eBMW S1000RR \u0026amp; S1000RR HP4 AiM EVO4S Plug \u0026amp; Play Cable\u003c\/h3\u003e\n\u003cp\u003eThe AiM ECU plug \u0026amp; play cable has been specifically designed for BMW bikes. Allowing easy installation to an EVO4S Data Logger. With a 7-pin 712 male binder connection.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eBMW plug \u0026amp; play cable\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e7 pin - 712 male binder connection\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eReceive data\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eSuitable for EVO4S\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch3\u003eBMW Plug \u0026amp; Play ECU Cable\u003c\/h3\u003e\n\u003cp\u003eThe AiM ECU plug \u0026amp; play cable has been specifically designed for the BMW bike. This plug \u0026amp; play cable can be used for the EVO4S.\u003c\/p\u003e\n\u003cp\u003eThe cable is an easy fitment to your bike and allows ECU data to be logged. \u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003ePlease Note:\u003c\/strong\u003e If you are unsure this ECU cable will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003ePlug \u0026amp; Play\u003c\/h3\u003e\n\u003cp\u003eThe plug \u0026amp; play cable currently fits the following BMW bike models:\u003c\/p\u003e\n\u003cdiv class=\"OTechMXDiv OTechMXDiv-2cols OTechMXDiv-Responsive\"\u003e\n\u003cdiv class=\"OTechMXDiv-Col OTechMXDiv-Sub\"\u003e\u003cimg class=\"MX-FitmentBike\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/BMW_Bike_2.png?v=1620402151\" alt=\"Aim Cobra ECU For Honda Motocross Bikes\"\u003e\u003c\/div\u003e\n\u003cdiv class=\"OTechMXDiv-Col OTechMXDiv-Sub\" style=\"display: flex !important; flex-direction: row; flex-wrap: wrap;\"\u003e\n\u003cdiv class=\"MotocrossFitment\"\u003e\n\u003ctable class=\"MotocrossFitmentTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003cth colspan=\"2\"\u003e\u003cimg class=\"MX-FitmentManufacturer\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/BMW_Solo_Smartycam_Logo.png?v=1620311866\"\u003e\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"MotoCell\"\u003eS1000RR - 2009-2014\u003c\/td\u003e\n\u003ctd class=\"MotoCell\"\u003eS1000RR - From 2015\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"MotoCell\"\u003eS1000RR HP4 - 2013-2014\u003c\/td\u003e\n\u003ctd class=\"MotoCell\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eExample data protocols\u003c\/h3\u003e\n\u003cp\u003eExample data protocols sampled include RPM, Active gear, Vehicle speed, Front wheel speed, Rear wheel speed warning led, Engine coolant temperature, Brake pressure, Throttle position, Speed, ABS intervention, ALC intervention, Low fuel level, Traction control, Oil pressure, Map menu and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003ePlease Note:\u003c\/strong\u003e For these models\/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Solo_2_Connection_Example.png?v=1614780014\" style=\"width: 100%;\"\u003e\u003c\/h3\u003e\n\u003ch3\u003eExpand Your System\u003c\/h3\u003e\n\u003cp\u003eThese are some of the items that can be added to your bike for incrementing performance and data.\u003c\/p\u003e\n\u003ch4\u003e\u003cbr\u003e\u003c\/h4\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\" alt=\"Visit Aim Academy\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\" alt=\"Visit Aim Tech Support\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\" alt=\"Download Race Studio Software\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical\u003c\/h5\u003e\n\u003ch3\u003eBMW S1000RR \u0026amp; S1000RR HP4 AiM EVO4S Plug \u0026amp; Play Cable\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eBelow is a pinout drawing for the BMW EVO4S plug \u0026amp; play connection cable\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/BMW_S1000RR_S1000RR_HP4_AiM_EVO4S_Plug_Play_Cable_Pinout_32a8cfd8-4b29-4b20-a15f-a4a967605f25.png?v=1620734410\" alt=\"\" data-mce-fragment=\"1\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eBMW S1000RR \u0026amp; S1000RR HP4 AiM EVO4S Plug \u0026amp; Play Cable\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eBMW S1000RR, S1000RR HP4 Plug \u0026amp; Play connection cable\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/docs\/Solo2+Solo2DL+EVO4S_per_BMWS1000RR_101_eng.pdf\" title=\"BMW Technical Sheet\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/docs\/Solo2+Solo2DL+EVO4S_per_BMWS1000RR_101_eng.pdf\" title=\"BMW Technical Sheet\" target=\"_blank\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"AiM Accessories","offers":[{"title":"Default Title","offer_id":39323871772774,"sku":"BMW-PP-EVO","price":70.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_bmw_solo2dl_plugandplaycable_00.webp?v=1781603362","url":"https:\/\/www.aimshop.com\/it\/products\/bmw-s1000rr-s1000rr-hp4-aim-evo4s-logger-plug-play-cable","provider":"AimShop.com","version":"1.0","type":"link"}
